up-to-date list of supported annotations? [message #12486] |
Thu, 12 February 2009 05:10  |
Hi, I tried a few more of the @gmf annotations listed at
http://epsilonlabs.wiki.sourceforge.net/EuGENia,
among them things like ... figure="...", color="..."
When defining explicitly figure="roundedrectangle" (just to make this
explicit, even though that's the default) then - when generating the
diagram code - this leads to:
roundedrectangle cannot be resolved to a type ProcessEditPart.java
test.diagram/src/test/diagram/edit/parts line 217 Java Problem
The method add(WrappingLabel) is undefined for the type
ProcessEditPart.ProcessFigure ProcessEditPart.java
test.diagram/src/test/diagram/edit/parts line 242 Java Problem
The method setBackgroundColor(Color) is undefined for the type
test.diagram/src/test/diagram/edit/parts line 230 Java Problem
Type mismatch: cannot convert from ProcessEditPart.ProcessFigure to
IFigure ProcessEditPart.java test.diagram/src/test/diagram/edit/parts
line 97 Java Problem
I guess only the first is the real problem, the others seem to be
consequential bugs. Shall I open a Bugzilla?
Michael
Re: up-to-date list of supported annotations? [message #565221 is a reply to message #12486] |
Thu, 12 February 2009 05:15  |
Hi Michael,
Typo (albeit big one). It should be "rounded" instead of
"roundedrectangle". Could you please open a bug and post the link here
and I'll fix it in the wiki page asap.
> Michael
Dimitris
FUDForum. Page generated in 0.26089 seconds
