Home » Eclipse Projects » Mylyn » What algorithm does Mylyn use for color in task list?
What algorithm does Mylyn use for color in task list? [message #12446] |
Fri, 13 July 2007 13:32  |
What algorithm is used to decide what color to display. I haven't changed
the default settings for colors in Windows->Preferences, but today (Friday)
everything went red. End of week. None of the red tasks have completion
dates, so what is it telling me?
Re: What algorithm does Mylyn use for color in task list? [message #16061 is a reply to message #14324] |
Thu, 19 July 2007 15:07   |
Originally posted by: beatmik.acm.org
The reason we don't currently do this is that the UI takes the premise
that a single scheduled date is the common case for most tasks, and that
tasks get deferred very frequently. In other words, we're leaning much
more heavily to David Allen's "Getting Things Done" approach of time
management than to a Microsoft start/end date style which should be
better overall for project management but can also be much more tedious
for day-to-day task management.
But note that we are very close to the "start date < now < end date"
approach, just that we make the day explicit (similar to how we make the
workweek explicit). So when "now" is the same day as the start date the
task goes blue. That said, I would like to explore this further in case
it helps us resolve how frequently tasks go red in the Task List.
Here's a quick cut at altering the current policy to incorporate these
suggestions, let me know what you think
* Tasks whose scheduled date is today continue to go blue so that they
stand out without being annoyingly read. They stay blue until they are
done or hit their end date.
* Tasks that have a due date go red once they hit that end date.
This would address the current problem of frequently having to
re-schedule your red tasks for today. The red was meant to encourage
re-scheduling things that have passed their date, but the blue might do
a good enough job of that and make things that are actually overdue (and
not just in need of rescheduling) more explicit. If you end up with too
much blue on a given day you then re-schedule things to be black (future
days this week) or to disappear (delegate to a future week.
Mik
Stefan Langer wrote:
> I tend to agree with Dave. It would be much clearer and more concise
> with other scheduling facilities to use the start date < now < end date
> for the highlighting. This would imply that it is nessecary to have a
> start date when an end date is defined and it is possible to leave out
> the end date which means indefinite or to leave out both which simply
> means this task is not scheduled at all.
> Stefan
> Dave Syer schrieb:
>> Mik,
>> That's much clearer thanks. But I don't see why you need two
>> different highlighting rules for start and end date - why not just
>> have "active" tasks (with start date <= now <= end date) blue, and
>> overdue tasks (now > end date) red? I see that it makes sense to have
>> an implied end date at the end of the day if it is not expicitly
>> specified, but the current behaviour doesn't seem intuitive.
Re: What algorithm does Mylyn use for color in task list? [message #17411 is a reply to message #16061] |
Thu, 19 July 2007 15:33   |
Mik,
That sounds perfect to me.
Dave.
"Mik Kersten" <beatmik@acm.org> wrote in message
news:f7ocqp$emv$1@build.eclipse.org...
> management than to a Microsoft start/end date style which should be better
> overall for project management but can also be much more tedious for
> it helps us resolve how frequently tasks go red in the Task List. Here's a
> quick cut at altering the current policy to incorporate these suggestions,
> This would address the current problem of frequently having to re-schedule
> your red tasks for today. The red was meant to encourage re-scheduling
> things that have passed their date, but the blue might do a good enough
> job of that and make things that are actually overdue (and not just in
> need of rescheduling) more explicit. If you end up with too much blue on
> a given day you then re-schedule things to be black (future days this
> Mik
>> I tend to agree with Dave. It would be much clearer and more concise with
>> other scheduling facilities to use the start date < now < end date for
>> the highlighting. This would imply that it is nessecary to have a start
>> date when an end date is defined and it is possible to leave out the end
>> date which means indefinite or to leave out both which simply means this
>> Stefan
>> Dave Syer schrieb:
>>> Mik,
>>> That's much clearer thanks. But I don't see why you need two different
>>> highlighting rules for start and end date - why not just have "active"
>>> tasks (with start date <= now <= end date) blue, and overdue tasks (now
>>> > end date) red? I see that it makes sense to have an implied end date
>>> at the end of the day if it is not expicitly specified, but the current
Re: What algorithm does Mylyn use for color in task list? [message #18615 is a reply to message #17411] |
Sun, 22 July 2007 12:59   |
Originally posted by: rob.elves.eclipse.org
+1 - I'd like to try that scheme out. But I'll need to change some (bad)
habits such as intentionally leaving tasks red as nagging reminders.
Since some Bugzilla repositories support shared/common due dates,
intentionally setting a task as overdue will not be practical for a
personal use case such as this.
-Rob
Dave Syer wrote:
> Mik,
> Dave.
>> Mik
>>> Stefan
>>> Dave Syer schrieb:
>>>> Mik,
Re: What algorithm does Mylyn use for color in task list? [message #18859 is a reply to message #18615] |
Tue, 24 July 2007 22:17  |
+1 that we experiment with a scheme modified along these lines.
However, note that yours is more than a personal use case, with the
scheme exactly as is we would be losing some information that other
users could currently be relying on.
Currently you look at your Task List in the morning and see a bunch of
things in red, and other things in blue. The things in red are likely
to be things that require first attention because they were scheduled to
be done yesterday or before, but are not done yet. If we went with the
proposed scheme as is we would lose this distinction.
One thing that we could experiment with is making it more clear that the
sorting sorts by scheduled date. However, the UI would be confusing if
there was no visual feedback for scheduling for today a task that was
over its scheduled date. So we might need to retain some kind of visual
feedback.
David: could you please file a bug report for this and post the URL? We
can start some experimentation in the dev builds.
Mik
Re: What algorithm does Mylyn use for color in task list? [message #571802 is a reply to message #12446] |
Fri, 13 July 2007 15:06  |
See the Task List's view menu's "Show UI Legend" action for an
explanation of the colors and a link to how to change them.
Mik
Re: What algorithm does Mylyn use for color in task list? [message #571851 is a reply to message #12565] |
Fri, 13 July 2007 18:05  |
Thanks, but that wasn't the question - the UI Legend (useful by the way,
thank you) just says red is "Past scheduled date". Everything is red, but I
don't understand why - nothing is overdue by my calculation. If a task
doesn't have a scheduled end date, why would it be red today and not
yesterday?
news:f78if1$kjn$3@build.eclipse.org...
>> changed the default settings for colors in Windows->Preferences, but
>> today (Friday) everything went red. End of week. None of the red tasks
>> have completion dates, so what is it telling me?
> See the Task List's view menu's "Show UI Legend" action for an explanation
> Mik
Re: What algorithm does Mylyn use for color in task list? [message #571877 is a reply to message #12604] |
Fri, 13 July 2007 18:25  |
I figured something out but I still don't undertstand. It seems that Mylyn
thinks something is past scheduled date if it is scheduled to start earlier
than today. What about the end date? Surely it is only red if it is not
finished but scheduled to complete before today?
So I can switch all my angry red tasks to black again by cancelling the
start date, but that seems to defeat the object somehow. Don't you think?
Re: What algorithm does Mylyn use for color in task list? [message #571919 is a reply to message #12624] |
Fri, 13 July 2007 21:15  |
Yes, that would defeat the objective so instead what's recommended is to
schedule for today (or a later day in the week, or defer) when wanting
to get rid of the angry red in the morning or on Monday. For details
see the "Task management and personal planning" section of:
http://www-128.ibm.com/developerworks/java/library/j-mylar1/
Mik
Re: What algorithm does Mylyn use for color in task list? [message #572792 is a reply to message #12729] |
Tue, 17 July 2007 12:37  |
Dave Syer wrote:
> Thanks. From the article in the link: "At the end of the workday, any tasks
> that should have been completed but weren't turn red". But the red tasks
> are those whose *start* date are earlier than today, not the scheduled end
> date. Surely it makes more sense to flag as red if you overrun the end
> date, not the start date?
Good point. This is related to a subtlety of what it means to schedule
a task for Today, which schedules it for the end of the workday and tuns
it blue instead of red. The point of that is to avoid needing to
continually re-schedule start times throughout your workday. I've added
an explanation to:
http://wiki.eclipse.org/Mylyn_User_Guide#Scheduling
Mik
Re: What algorithm does Mylyn use for color in task list? [message #572927 is a reply to message #14226] |
Wed, 18 July 2007 02:35  |
Mik,
highlighting rules for start and end date - why not just have "active" tasks
(with start date <= now <= end date) blue, and overdue tasks (now > end
date) red? I see that it makes sense to have an implied end date at the end
of the day if it is not expicitly specified, but the current behaviour
Dave.
news:f7ir7t$b89$1@build.eclipse.org...
> Good point. This is related to a subtlety of what it means to schedule a
> task for Today, which schedules it for the end of the workday and tuns it
> blue instead of red. The point of that is to avoid needing to continually
> re-schedule start times throughout your workday. I've added an
> explanation to:
> Mik
Re: What algorithm does Mylyn use for color in task list? [message #572984 is a reply to message #14293] |
Wed, 18 July 2007 03:43  |
Stefan
Dave Syer schrieb:
> Mik,
> Dave.
>> explanation to:
>> Mik
Re: What algorithm does Mylyn use for color in task list? [message #573548 is a reply to message #14324] |
Mik
> Stefan
> Dave Syer schrieb:
>> Mik,
Re: What algorithm does Mylyn use for color in task list? [message #573856 is a reply to message #16061] |
Mik,
Dave.
> Mik
>> Stefan
>> Dave Syer schrieb:
>>> Mik,
Re: What algorithm does Mylyn use for color in task list? [message #574365 is a reply to message #17411] |
-Rob
Dave Syer wrote:
> Mik,
> Dave.
>> Mik
>>> Stefan
>>> Dave Syer schrieb:
>>>> Mik,
Re: What algorithm does Mylyn use for color in task list? [message #574778 is a reply to message #18615] |
feedback.
Mik
Current Time: Mon Jul 21 20:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.08414 seconds
