Home » Modeling » TMF (Xtext) » Re: [TCS] Problem with serializer 2 [model to text]
Re: [TCS] Problem with serializer 2 [model to text] [message #12435] Tue, 29 April 2008 05:13
> 1) I am specifying the CSP hide operator syntax like this:
> operatorTemplate Hide (operators = hideOp, source = behavior)
> : channels
> template HiddenChannels
> : "{" channels {separator = ",", refersTo = name} "}"
> and in the symbols and operator sections:
> symbols {
> .. hide = "\\\\": leftNone, rightNone;
> operators BehaviorOp {
> priority 4 {
> hideOp = hide, 2;
Can you try using:
hide = "\\"
This should work for the extraction.
> The code is parsed without problem but when I serialize a model
> I get "D = A21\\{ display }". That means, I get two slashes instead
> of one! It should be "D = A21\{ display }"
According to this, I suppose this causes a problem with injection?
If yes, then there is a bug: the grammar generator should escape it, and
you should not have to do it.
Could you please post a bug about this?
Thanks.
> 2) The other problem is with the serialization of the CSP prefix
> operator. The syntax, symbol, and operator priority are:
> operatorTemplate Prefix (operators = prefixOp, source = next)
> : action
> rarrow = "->" : leftSpace, rightSpace;
> priority 2, right {
> prefixOp = rarrow, 1;
> I am getting "M1 = M2 -> write" when I should get "M1 = write -> M2".
> It is serializing it backwards!! It is switching the "next" and the
> "action"
> attributes positions.
If I understand correctly, "write" is the action, right?
If yes, then there is also a bug for this. Can you please open a bug for
this?
Thanks.
> I am using an ANT task (extractor) with the following information:
> <property name="tcs-ecore" value="/CSP/Syntax/CSP.ecore" />
> <am3.loadModel modelHandler="EMF" name="MM.tcs" metamodel="TCS"
> path="${tcs-ecore}" />
> <am3.saveModel model="M" path="${sample}-2.csp">
> <extractor name="ebnf">
> <param name="format" value="MM.tcs"/>
> <param name="indentString" value=" "/>
> <param name="serializeComments" value="true"/>
> </extractor>
> </am3.saveModel>
> Could anyone tell me where is the implementation of this task? So I
> can check its behavior? Is it a bug or am I doing something wrong? :p
> I couldnt find much information about the operator template, specially
> about the right or left association and the number of operators: 1 or 2,
> for
> instance.
Extraction is implemented in org.eclipse.gmt.tcs.extractor, which is in
/cvsroot/technology/org.eclipse.gmt/org.eclipse.gmt.tcs/plug ins.
Do not hesitate to contribute a patch on bugzilla as well.
Thanks.
Frédéric Jouault
Previous Topic:xText Defining Sequences
Next Topic:Re: [TCS] Problem with serializer
Current Time: Wed Jul 16 03:31:02 EDT 2025
Powered by FUDForum. Page generated in 0.08589 seconds
