Home » Language IDEs » Java Development Tools (JDT) » Runtime.exec child Process not separate?
Runtime.exec child Process not separate? [message #12408] Fri, 02 May 2003 16:13 Go to next message
Originally posted by: sherbert.RigakuMSC.com
Here is my code:
import java.io.IOException;
public class Test {
System.out.println("test begin");
Runtime rt = Runtime.getRuntime();
try {
String[] cmdArray = new String[]{
"cmd", "/c", "start \"Test Console\" echo Hello"
Process p = rt.exec(cmdArray);
catch (IOException e) {
System.err.println("exception caught: "+e);
System.out.println("test end");
When I run this simple application from inside Eclipse, the application's
life span is at most 2 seconds. The problem is that the Eclipse debugger
thinks my application is still running until I close the command console.
The command console was launched as a separate process and should not even
have any hooks into the JVM. If you are on Windows you can try this and see
what I'm talking about. This is causing me serious grief. When I use
Runtime.exec I expect to start a completely separate process. How and why
does Eclipse even know about this process?
Re: Runtime.exec child Process not separate? [message #12920 is a reply to message #12408] Sat, 03 May 2003 10:47 Go to previous message
Why is this a problem?
- Jared
Previous Topic:Problem with Eclipse 2.1 and JDK 1.4.1_02
Next Topic:Can't get Ant to accpet ecllipse variables as arguments
Current Time: Tue Jul 22 01:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.03048 seconds
