Home » Language IDEs » Java Development Tools (JDT) » Problem with Eclipse 2.1 and JDK 1.4.1_02
Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12399] Fri, 02 May 2003 15:15 Go to next message
Originally posted by: mb.nose.demon.nl
Hi there,
I installed the new Eclipse 2.1 with Lomboz 2.1 and EASIE for JBoss (1.2.0).
I have JDK 1.4.1_02 installed and made all the configurations as noticed in
the appropriate docs. When I try to start the JBoss server I get the
following error:
"Error occured during initialization of VM
java/lang/NoClassDefinitionFoundError: java/lang/Object"
I also tried with JDK 1.4.0_01 but with the same error.
The error is quite obvious but does anyone know what causes this?
Michiel.
Re: Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12418 is a reply to message #12399] Fri, 02 May 2003 17:29 Go to previous messageGo to next message
Michiel,
I got a similar NoClassDefFoundError exception today when installing
Eclipse 2.1 with Sun's JRE 1.4.1_02 on my W2K box. The only additional
plugin was the one my company is developing (contributes a perspective
and a new editor). However, everything has worked fine for awhile on
JRE 1.4.0_02. Here's the contents of the .log file:
Doug
!ENTRY org.eclipse.core.launcher 4 0 May 02, 2003 15:21:01.881
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException:
java.lang.NoClassDefFoundError: javax/xml/transform/Source
at java.lang.Class.getConstructor0(Native Method)
at java.lang.Class.getConstructor(Class.java:922)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:701)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:485)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:130)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:158)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:155)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:98)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:653)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:278)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:965)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:1692)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:369)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:413)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:1188)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1185)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1074)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Michiel Bakker wrote:
> Hi there,
> following error:
> Michiel.
Re: Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12428 is a reply to message #12399] Fri, 02 May 2003 19:30 Go to previous messageGo to next message
> Hi there,
> following error:
I see the same problem when I create .jar files. What I noticed is that my
project properties shows all my external .zips and .jars in the Libraries
pane, and they're all selected in the "Order and Export" pane. But, when I
go to export the jar file, my Oracle JDBC jar file is not in the "lib"
list, even though all the others are.
If I export the jar the size is too small, and I also get the NoClassDef
... error when trying to launch the jar.
Eclipse on my Win2K and Solaris host are both current and both started
having the problem after I upgraded. JDeveloper on both systems compiles
and creates the jar correctly, which then runs without error. (All source
and .zip and .jars in my library are the same as they've been pulled in
from my CVS repository just before compiling.)
Various combinations of reloading Eclipse and checking out the project
don't make a difference.
Greg
Re: Problem with Eclipse 2.1 and JDK 1.4.1_02 [message #12438 is a reply to message #12418] Sat, 03 May 2003 05:50 Go to previous message
When I open a project I created in the proir version of Eclipse I can
compile and run the server. Then, when I open a project created in 2.1 the
server suddenly runs too.
Try to do the same as I did. It might help, although I several error from my
server (JBoss). 'have to gigure this on out.
"Doug Spelce" <doug@journee.com> wrote in message
news:b8uo0n$hmq$1@rogue.oti.com...
> Michiel,
> Doug
> !STACK
> at
> at
> at
ssLoader.java:112)
> at
> at
> at
> at
> at
> at
> at
> at
:155)
> at
> at
> at
> at
65)
> at
3)
> at
> at
> at
> at
a:845)
> > Hi there,
(1.2.0).
in
> > following error:
> > Regards,
> > Michiel.
Previous Topic:interaction between multiple windows
Next Topic:Runtime.exec child Process not separate?
Current Time: Tue Jul 22 01:42:26 EDT 2025
Powered by FUDForum. Page generated in 0.06295 seconds
