Compatibility with EclipseME [message #12395] |
Tue, 29 January 2008 17:15  |
Originally posted by: sergei.synopsia.net
Are any versions of Subversive plugin compatible with EclipseME 1.7.7? If
yes, which ones? Otherwise, could you recommend some other SVN plugin?
Sergei
org.eclipse.pde.ui (was: Compatibility with EclipseME) [message #12404 is a reply to message #12395] |
Wed, 30 January 2008 17:32   |
Hello again,
I working with Motodev Studio, which is based on Eclipse 3.3 with
EclipseME 1.7.7. Tried installing subversive, which required Mylyn Bridge,
which in turn requires something else -- here is the error message:
Mylyn Bridge: PDE, CVS and Ant (2.3.0.I20080125-1200) requires plug-in
"org.eclipse.pde.ui".
Can someone please point me to where I might be able to get that?
Thanks in advance.
Sergei S. wrote:
> Sergei
Re: org.eclipse.pde.ui [message #12413 is a reply to message #12404] |
Wed, 30 January 2008 23:50   |
Sergei S. wrote:
> Hello again,
> Bridge, which in turn requires something else -- here is the error message:
> Thanks in advance.
> Sergei S. wrote:
>> If yes, which ones? Otherwise, could you recommend some other SVN plugin?
>> Thanks,
>> Sergei
I am not sure, what else is behind EclipseME 1.7.7 (I just finished an
article about Mobile Eclipse Development, so I looked at it, but not
every single Plugin it uses ;-) but you probably need to check older
(propriatory) versions of Subversive still hosted by Polarion.
Either their UpdateManager still works, or they can be downloaded somehow.
Of course if it was totally incompatible, the alternative SVN Team
client by ColabNet (Subclipse or so I think?) might work, too.
FUDForum. Page generated in 0.05214 seconds
