How to test a BeanInfo [message #134862] |
Sun, 14 January 2007 11:22  |
I've written a BeanInfo for a custom component and now I want to see if
it is loaded into the remote-VM. How can I test this, either by using
the debugger or some test code?
Thanks in advance,
Daniel
Re: How to test a BeanInfo [message #134982 is a reply to message #134973] |
Wed, 17 January 2007 19:20  |
Rich Kulp schrieb:
> The problem is you need the jar that contains the
> org.eclipse.jem.beaninfo.vm.BaseBeanInfo class. It is contained in the
> org.eclipse.jem.beaninfo plugin. That needs to be on your classpath too.
I know, but how do I get this jar into the classpath of the remote-vm?
As far as I understood VE, all BeanInfo classes are in the remove-vm and
provide more information to JEM about UI components. It would especially
be interesting how the org.eclipse.ve.jfc plugin has solved this problem.
Kind regards,
Daniel
> Daniel Rohe wrote:
>> Daniel Rohe schrieb:
>>> Hello,
>>> if it is loaded into the remote-VM. How can I test this, either by
>>> using the debugger or some test code?
>>> Thanks in advance,
>>> Daniel
>> I've tested my plugin in a separate Eclipse instance. In this instance
>> I get the following error:
>> IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
>> java.lang.Error: Unresolved compilation problems:
>> The import org.eclipse.jem.beaninfo.vm cannot be resolved
>> BaseBeanInfo cannot be resolved to a type
>> I've tried to create my own BeanInfo for the layout just like one of
>> the bean infos for the JFC classes in the org.eclipse.ve.jfc plugin.
>> To solve my problem can someone point me to the correct location to
>> look for.
>> Kind regards,
>> Daniel
Re: How to test a BeanInfo [message #615000 is a reply to message #134862] |
Tue, 16 January 2007 22:13  |
> Hello,
> Thanks in advance,
> Daniel
I've tested my plugin in a separate Eclipse instance. In this instance I
I've tried to create my own BeanInfo for the layout just like one of the
bean infos for the JFC classes in the org.eclipse.ve.jfc plugin. To
solve my problem can someone point me to the correct location to look for.
Kind regards,
Daniel
Re: How to test a BeanInfo [message #615001 is a reply to message #134962] |
Wed, 17 January 2007 10:02  |
>> Hello,
>> Thanks in advance,
>> Daniel
> Kind regards,
> Daniel
Rich Kulp
Re: How to test a BeanInfo [message #615002 is a reply to message #134973] |
Kind regards,
Daniel
>>> Hello,
>>> Thanks in advance,
>>> Daniel
>> look for.
>> Kind regards,
>> Daniel
FUDForum. Page generated in 0.28013 seconds
