Home » Archived » BIRT » BIRT on Tomcat - caching
BIRT on Tomcat - caching [message #134799] Thu, 23 February 2006 01:34 Go to next message
Originally posted by: simon.pearce.bt.com
Running a BIRT report under Tomcat, it creates a file called
reportname.rpddocument
Then next time you call up the report - even with different parameters -
you get the cached version. Why is this - and how can I make it make a new
report each time?
This even happens with the sample report supplied with BIRT.
I am running a very recent version (runtime 2.0.1) - and I don't recall
this as a problem from earlier, but I'm not certain.
thanks
Simon
Re: BIRT on Tomcat - caching [message #134863 is a reply to message #134799] Thu, 23 February 2006 03:32 Go to previous messageGo to next message
Hello Simon,
try to add __overwrite=true to your URL.
so your URL should look something like this:
http://birtserver:8080/birt-viewer/frameset?__report=yourrep ort.rptdesign&__overwrite=true
this worked for me!
hope that helps!
Re: BIRT on Tomcat - caching [message #135073 is a reply to message #134863] Thu, 23 February 2006 08:55 Go to previous messageGo to next message
Originally posted by: jarif.despammed.com
Mr. Burns wrote:
> Hello Simon,
> this worked for me!
> hope that helps!
Even that seems to fail sometimes. Looks like the browser caches the
report too, so adding a random (or time based) dummy parameter to the
url helps in that.
It is also possible to add __document=name parameter, and using
something special in it. I use "rptcache/<sessionid>.rptdocument ( I
have created a rptcache directory and using one file per servlet session
so that the users do not overwrite each others reports).
Re: BIRT on Tomcat - caching [message #135470 is a reply to message #135073] Thu, 23 February 2006 17:29 Go to previous message
thanks for those suggestions. I have done both and it seems to work fine.
This newgroup is wonderful.
Previous Topic:Difference between "Data" and "Text" data report elements?
Next Topic:Crosstabs
Current Time: Fri Jul 18 05:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.31530 seconds
