Home » Eclipse Projects » Subversive » FastTrack and Subversive 0.7
FastTrack and Subversive 0.7 [message #12386] Tue, 29 January 2008 02:59 Go to next message
Hi!
Now it is impossible to install FastTrack with Subversive 0.7.
Are there any plans for FastTrack, Subversive 0.7 integration?
Thanks.
Ilya Klyuchnikov.
Re: FastTrack and Subversive 0.7 [message #12423 is a reply to message #12386] Wed, 30 January 2008 23:55 Go to previous messageGo to next message
Ilya Klyuchnikov wrote:
> Hi!
> Thanks.
> Ilya Klyuchnikov.
Is there any real future for FastTrack, or doesn't Mylyn make it more or
less irrelevant ?;-)
I suggest, since you did quite a good job getting the Eclipse project
started after all, to consider at least a Mylyn Connector for this kind
of "Server". If it was to work as an easy standalone or distributed Task
Management system, it could be a valid option among others like Bugzilla
& Co. but I don't think the proprietary UI and plugin for it are really
justified now that Mylyn is built into practically every Eclipse release
since Europa.
Werner
Re: FastTrack and Subversive 0.7 [message #12928 is a reply to message #12386] Mon, 04 February 2008 08:40 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hi Ilya,
AFAIK FastTrack with support of Subversive and new Polarion 3.0 tracker
should be available at the end of March 2008.
Previous Topic:Compatibility with EclipseME
Next Topic:Bad problems creating tags
Current Time: Tue Jul 22 12:07:48 EDT 2025
Powered by FUDForum. Page generated in 0.03883 seconds
