Home » Modeling » GMF (Graphical Modeling Framework) » How to create a picture without opening the editor
How to create a picture without opening the editor [message #134734] Tue, 12 June 2007 03:19 Go to next message
Originally posted by: tyhoho.gmail.com
Hi there,
Does anyone have idea about how to create a picture without opening the
editor?
I use the EMF createResouce and can only get the model file correctly,but
I don't know how to create the diagram file. The diagram file derived from
the model file is not right,it can noly display node,some of the edges are
missing.
Thanks for any hints.
Tina
Re: How to create a picture without opening the editor [message #134815 is a reply to message #134734] Tue, 12 June 2007 04:13 Go to previous messageGo to next message
If you start with diagram file uri for #createResource(), that would give
you a diagram instance.
Then, use org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il to
render it as a picture.
Artem
"Tina Chen" <tyhoho@gmail.com> wrote in message
news:e11847cc11a8cca3cda838071768024f$1@www.eclipse.org...
> Hi there,
> editor? I use the EMF createResouce and can only get the model file
> correctly,but I don't know how to create the diagram file. The diagram
> file derived from the model file is not right,it can noly display
> node,some of the edges are missing.
> Tina
Re: How to create the diagram file without opening the editor [message #134978 is a reply to message #134815] Tue, 12 June 2007 08:41 Go to previous message
Hi Artem,
Thanks for your response!
I don't mean to derive a picture from the diagram file.
I want to create a diagram file programmatically without opening the
editor.
sorry that I used the word "picture".
Tina.
> Artem
Previous Topic:forcing save in TransactionalCommand
Next Topic:(Corrected)How to create the diagram file without opening the editor
Current Time: Sun Jun 29 10:26:03 EDT 2025
Powered by FUDForum. Page generated in 0.07364 seconds
