Home » Archived » IMP » Known Problem: pathnames that include spaces
Known Problem: pathnames that include spaces [message #12370] Sun, 21 October 2007 11:41
Hi All,
As some of you have discovered, there are parts of IMP that can't
correctly process pathnames that have spaces in them. We had known
about a problem in this area relating to LPG (apologies if we have not
previously documented this adequately). It may also be that this
problem comes up with some other language/IDE services. The problems
should be related mainly to the use of wizards, such as in the creation
of wizard pages or the generation of service implementations. The
pathnames may come into play when we look up a schema (or other
information) for creating a page or when we look up a template for
generating a service implementation.
We will be looking into resolving these problems. In the meantime, if
you can install the IMP features into an Eclipse installation that is on
a path with no spaces, that should work better.
Again, our apologies if this has been an issue for you!
Stan Sutton
Previous Topic:Missing IMP projects available
Next Topic:Known Problem: pathnames that include spaces
Current Time: Tue Jul 22 17:52:32 EDT 2025
Powered by FUDForum. Page generated in 0.04803 seconds
