Home » Language IDEs » C / C++ IDE (CDT) » problem with shared library debug
problem with shared library debug [message #134561] Wed, 12 January 2005 03:38
Originally posted by: mcottret.laas.fr
I use eclipse and cdt to develop modules for our internal framework. Each
module generates through a configure/make/make install process a shared
lib with algorithms and a shared lib for using those algorithms in Tcl
(dynamically loaded in an interperter), installed somewhere in the
framework but out of the module tree. Each module tree is a project under
eclipse.
how can I use the eclipse debug perspective in order to debug my lib ? I
made symbolics links to the interperter binaries and shared libraries
directories, so I can find then in the debug configuration panel but no
breakpoint works then. (I use the attach process debug mode)
I also tried to add my shared libraries directory in the gdb option panel
with automatic symbols load and stop on library event but I had the
following error:
Error initializing shared library option: Undefined show command:
"solib-search-path". try "help show".
I use eclipse 3.1M4 with CDT 3.0.0 (the first build) on a powerbook 1GHz
with 768 RAM.
if anybody has an idea ?
thanks a lot
Maxime Cottret
PhD Student - LAAS-CNRS (FRANCE)
Previous Topic:Minimal eclipse plugins to run CDT+ CVS ?
Next Topic:Add include paths to managed makefile project
Current Time: Sat Jul 26 14:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.28508 seconds
