Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Transaction Questions
Transaction Questions [message #12360] Thu, 19 January 2006 06:55 Go to next message
Originally posted by: stepper.sympedia.de
Hi Christian,
I'm just evaluating the new Transaction API for use in my product.
Here are some questions:
1) Is it necessary that own ResourceSets implement IEditingDomainProvider to be used with TXEditingDomain?
2) Is a concurrent thread allowed to read (only!) the ResourceSet of the TXEditingDomain directly, for example to validate in background?
3) Where is the relation between the physical files in the workspace and their in memory representation, e.g. Resources in the ResourceSet? What shall an editor do when the user hits "Save"?
Cheers
/Eike
Re: Transaction Questions [message #12371 is a reply to message #12360] Thu, 19 January 2006 07:51 Go to previous messageGo to next message
I'm just about to analyze your Transaction-related changes to the EXTLibraryEditor.
It would be easier, if you annotated all your changes with @generated NOT (or @ADDED).
Btw. I had to comment out the following in ResourceLoadedListener
IEditorReference[] editors = page.findEditors(
new FileEditorInput(file),
" org.eclipse.emf.workbench.examples.extlibrary.presentation.E XTLibraryEditorID ", //$NON-NLS-1$
IWorkbenchPage.MATCH_ID | IWorkbenchPage.MATCH_INPUT);
page.closeEditors(editors, false);
MATCH_ID and MATCH_INPUT can't be resolved.
Cheers
/Eike
Eike Stepper schrieb:
> Hi Christian,
> Cheers
> /Eike
Re: Transaction Questions [message #12379 is a reply to message #12360] Thu, 19 January 2006 08:38 Go to previous messageGo to next message
Hi, Eike,
See responses in-line, below.
Christian
Eike Stepper wrote:
> Hi Christian,
No. The TXEditingDomain.Factory links the resource set to its editing
domain by attaching an Adapter to it; the getEditingDomain(ResourceSet)
method does not require the IEditingDomainProvider interface. However, if
you do implement that interface for some other reason, then you will need
to ensure that it is consistent with what the factory thinks the
association is.
I don't understand your question. A thread may actually read multiple
resource sets in different editing domains, but then you would need to be
wary of deadlocks (perhaps by implementing some kind of domain ordering).
Note that the Transaction API doesn't actually implement concurrency as
such; multiple "concurrent" readers of a resource set must cooperatively
yield read access to others. And write access is exclusive of all readers,
yielding or otherwise.
The WorkspaceSynchronizer class can provider the IResource representing an
EMF Resource. As you have probably seen already (indicated by your other
post), the example editor uses this in determining when it needs to refresh
from disk.
> Cheers
> /Eike
Re: Transaction Questions [message #12388 is a reply to message #12371] Thu, 19 January 2006 08:41 Go to previous messageGo to next message
Hi, Eike,
Marking the changes with some kind of comment is a good idea. Raise a
bugzilla and I'll see to it!
Regarding the code that you had to comment out: you need the M4 or later
version of Eclipse 3.2. This new findEditors() method is more correct than
the older simple editor-input-based findEditor() because it considers the
editor type as well, so that we do not accidentally close (e.g.) a text
editor.
Christian
> EXTLibraryEditor. It would be easier, if you annotated all your changes
> //$NON-NLS-1$ IWorkbenchPage.MATCH_ID | IWorkbenchPage.MATCH_INPUT);
> Cheers
> /Eike
>> Hi Christian,
>> Cheers
>> /Eike
Re: Transaction Questions [message #14466 is a reply to message #12388] Thu, 19 January 2006 17:20 Go to previous messageGo to next message
Christian W. Damus schrieb:
> Hi, Eike,
I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=124558
In the context of the generated editor the following bugzilla might also be interesting:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470
> editor.
I see. I've had some problems with M4 and switched back to M3.
I'll try newer I-builds...
/Eike
Re: Transaction Questions [message #14496 is a reply to message #12379] Thu, 19 January 2006 17:50 Go to previous messageGo to next message
> Hi, Eike,
> Cheers,
> Christian
> Eike Stepper wrote:
>>Hi Christian,
> association is.
I see. That is a nicer solution than EMF's own one ;-)
> from disk.
I should have been running the editor before looking at its code!
I very much like your solution that now there is a visual 1:1 representation
of modified files and editor instances.
Your Transaction component is really great work! Thanks for this ;-)
Cheers
/Eike
Re: Transaction Questions [message #14527 is a reply to message #14496] Thu, 19 January 2006 17:56 Go to previous messageGo to next message
Thanks for the positive feedback, Eike! That certainly helps to validate
the approach we're taking with this API.
Please don't hesitate to raise any issues that strike you (as I see you are
already doing). I look forward to them.
cW
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>>Hi Christian,
>> if you do implement that interface for some other reason, then you will
>> need to ensure that it is consistent with what the factory thinks the
>> association is.
>> an
>> refresh from disk.
> representation of modified files and editor instances.
> Cheers
> /Eike
Re: Transaction Questions [message #14555 is a reply to message #14466] Thu, 19 January 2006 18:00 Go to previous messageGo to next message
Yes, Eike,
I followed that newsgroup thread with some interest, but I hadn't had a look
at what you and Steven had contributed. I should do so.
cW
>> Hi, Eike,
> be interesting: https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470
>> than the older simple editor-input-based findEditor() because it
>> considers the editor type as well, so that we do not accidentally close
>> (e.g.) a text editor.
> Thanks
> /Eike
Re: Transaction Questions [message #14588 is a reply to message #14496] Fri, 20 January 2006 07:38 Go to previous message
--------------020900020601010109090306
Eike,
AdapterFactoryEditingDomain has these methods so it's not generally
necessary for a resource set to implement IEditingDomainProvider
directly; it can provide the support using an adapters:
static public EditingDomain getEditingDomainFor(Object object)
if (object instanceof IEditingDomainProvider)
EditingDomain editingDomain =
((IEditingDomainProvider)object).getEditingDomain();
return editingDomain;
else if (object instanceof EObject)
AdapterFactoryEditingDomain.getEditingDomainFor((EObject)obj ect);
else if (object instanceof FeatureMap.Entry)
return getEditingDomainFor(((FeatureMap.Entry)object).getValue());
else if (object instanceof IWrapperItemProvider)
return
getEditingDomainFor(((IWrapperItemProvider)object).getValue( ));
else
return null;
static public EditingDomain getEditingDomainFor(EObject object)
Resource resource = object.eResource();
if (resource != null)
IEditingDomainProvider editingDomainProvider =
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);
if (editingDomainProvider != null)
return editingDomainProvider.getEditingDomain();
else
ResourceSet resourceSet = resource.getResourceSet();
if (resourceSet instanceof IEditingDomainProvider)
((IEditingDomainProvider)resourceSet).getEditingDomain();
else if (resourceSet != null)
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc eSet,
return null;
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>> Hi Christian,
>> However, if
>> need
>> association is.
>>> and
>> representing an
>> other
>> refresh
>> from disk.
> representation
> Cheers
> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
directly; it can provide the support using an adapters:<br>
<blockquote><small>&nbsp; static public EditingDomain
getEditingDomainFor(Object object)</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; if (object instanceof IEditingDomainProvider)</small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EditingDomain editingDomain =
((IEditingDomainProvider)object).getEditingDomain();</small ><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return editingDomain;</small><br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; else if (object instanceof EObject)</small><br>
AdapterFactoryEditingDomain.getEditingDomainFor((EObject)obj ect); </small><br>
<small>&nbsp;&nbsp;&nbsp; else if (object instanceof FeatureMap.Entry)</small><br>
getEditingDomainFor(((FeatureMap.Entry)object).getValue());</small ><br>
<small>&nbsp;&nbsp;&nbsp; else if (object instanceof IWrapperItemProvider)</small><br>
getEditingDomainFor(((IWrapperItemProvider)object).getValue( )); </small><br>
<small>&nbsp;&nbsp;&nbsp; else</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return null;</small><br>
<small>&nbsp; }<br>
<br>
&nbsp; static public EditingDomain getEditingDomainFor(EObject object)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; Resource resource = object.eResource();<br>
&nbsp;&nbsp;&nbsp; if (resource != null)<br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; IEditingDomainProvider editingDomainProvider =<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; (IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (editingDomainProvider != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return editingDomainProvider.getEditingDomain();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; else<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ResourceSet resourceSet = resource.getResourceSet();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (resourceSet instanceof IEditingDomainProvider)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; EditingDomain editingDomain =
((IEditingDomainProvider)resourceSet).getEditingDomain();<br >
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return editingDomain;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if (resourceSet != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; editingDomainProvider =
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (editingDomainProvider != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return editingDomainProvider.getEditingDomain();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; return null;<br>
&nbsp; }<br>
</small></blockquote>
<br>
<br>
<br>
Eike Stepper wrote:
<blockquote cite="middqp53t$70j$1@utils.eclipse.org" type="cite"><br>
<br>
<br>
<blockquote type="cite">Hi, Eike,
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
<br>
<br>
Eike Stepper wrote:
<br>
<br>
<br>
<blockquote type="cite">Hi Christian,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
No.&nbsp; The TXEditingDomain.Factory links the resource set to its editing
<br>
<br>
method does not require the IEditingDomainProvider interface.&nbsp; However,
if
<br>
need
<br>
<br>
association is.
<br>
</blockquote>
<br>
<br>
<br>
<br>
<blockquote type="cite">3) Where is the relation between the
<br>
<br>
<br>
</blockquote>
<br>
<br>
an
<br>
EMF Resource.&nbsp; As you have probably seen already (indicated by your
other
<br>
refresh
<br>
from disk.
<br>
</blockquote>
<br>
<br>
representation
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
</blockquote>
<br>
</body>
</html>
--------------020900020601010109090306--
Re: Transaction Questions [message #563162 is a reply to message #12360] Thu, 19 January 2006 07:51 Go to previous message
Cheers
/Eike
> Hi Christian,
> Cheers
> /Eike
Re: Transaction Questions [message #563187 is a reply to message #12360] Thu, 19 January 2006 08:38 Go to previous message
Hi, Eike,
Christian
Eike Stepper wrote:
> Hi Christian,
association is.
from disk.
> Cheers
> /Eike
Re: Transaction Questions [message #563212 is a reply to message #12371] Thu, 19 January 2006 08:41 Go to previous message
Hi, Eike,
editor.
Christian
> Cheers
> /Eike
>> Hi Christian,
>> Cheers
>> /Eike
Re: Transaction Questions [message #563423 is a reply to message #12388] Thu, 19 January 2006 17:20 Go to previous message
> Hi, Eike,
> editor.
/Eike
Re: Transaction Questions [message #563449 is a reply to message #12379] Thu, 19 January 2006 17:50 Go to previous message
> Hi, Eike,
> Cheers,
> Christian
> Eike Stepper wrote:
>>Hi Christian,
> association is.
> from disk.
Cheers
/Eike
Re: Transaction Questions [message #563472 is a reply to message #14496] Thu, 19 January 2006 17:56 Go to previous message
cW
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>>Hi Christian,
>> association is.
>> an
>> refresh from disk.
> Cheers
> /Eike
Re: Transaction Questions [message #563502 is a reply to message #14466] Thu, 19 January 2006 18:00 Go to previous message
Yes, Eike,
cW
>> Hi, Eike,
> Thanks
> /Eike
Re: Transaction Questions [message #563528 is a reply to message #14496] Fri, 20 January 2006 07:38 Go to previous message
Eike,
return
else
return null;
else
return null;
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>> Hi Christian,
>> However, if
>> need
>> association is.
>>> and
>> representing an
>> other
>> refresh
>> from disk.
> representation
> Cheers
> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
<small>&nbsp; }<br>
<br>
&nbsp; {<br>
<br>
&nbsp; }<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
<br>
<br>
Eike Stepper wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
if
<br>
need
<br>
<br>
association is.
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
an
<br>
other
<br>
refresh
<br>
from disk.
<br>
</blockquote>
<br>
<br>
representation
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
</blockquote>
<br>
</body>
</html>
Previous Topic:[Announce] EMFT VALIDATION 1.0.0 I200601191249 is available
Next Topic:[Announce] EMFT VALIDATION 1.0.0 I200601191249 is available
Current Time: Sun May 11 01:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.06352 seconds
