Home » Eclipse Projects » GEF » Newbie: GEF standalone
Newbie: GEF standalone [message #134407] Wed, 26 May 2004 10:54 Go to next message
Is it doable to use GEF outside Eclipse (ie, not to implement an Eclipse
plug-in but a standalone application)?
Olivier
Re: Newbie: GEF standalone [message #134445 is a reply to message #134407] Wed, 26 May 2004 11:08 Go to previous messageGo to next message
Originally posted by: rlemaigr.ulb.ac.be
I have read somewhere that in theory it is not possible because gef have=
some dependencies with Eclipse. However, using draw2d alone outside of =
Eclipse is possible. But maybe with a little change in the code of GEF i=
t =
will become possible to use it elsewhere, I don't know...and I don't thi=
nk =
the gef engeneers have advantages to make it possible...
Check the page http://eclipsewiki.swiki.net/50#logicexamplestandalone
There is a guy there who is trying to modify the logic example to get it=
working outside of Eclipse and it seems to work but not all of it.
r=E9gis
On Wed, 26 May 2004 16:54:09 +0200, Olivier <onicolas@genigraph.fr> wrot=
e:
> 05-26-2004
> Is it doable to use GEF outside Eclipse (ie, not to implement an Eclip=
se =
> Olivier
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Newbie: GEF standalone [message #134470 is a reply to message #134445] Wed, 26 May 2004 12:20 Go to previous messageGo to next message
GEF should work with RCP + org.eclipse.ui.views if it's any consolation.
<rlemaigr@ulb.ac.be> wrote in message
news:opr8l4cvfxxn9g2u@xn--pcrgis-dva.mshome.net...
Eclipse is possible. But maybe with a little change in the code of GEF it
will become possible to use it elsewhere, I don't know...and I don't think
r
Re: Newbie: GEF standalone [message #134648 is a reply to message #134470] Thu, 27 May 2004 14:22 Go to previous message
Originally posted by: anonymous.zzz.net
Definitely yes. since I been developing RCP with GEF. You can develop RCP
with just following plug-in as dependents:
org.eclipse.ui
org.eclipse.gef,
org.eclipse.core.runtime.compatibility
note that because current RCP doesn't have geneneral purpose navigator, you
have to
develop your own. other than it's fine.
make sure you use latest M9/GEF20040521 release combination.
"Whitney Sorenson" <none@us.ibm.com> wrote in message
news:c92c2v$ip5$1@eclipse.org...
> r
Previous Topic:Checking constraints on a model wich rises Exceptions ?
Next Topic:SelectionActions and MultiPageEditorPart
Current Time: Mon Jul 21 21:57:04 EDT 2025
Powered by FUDForum. Page generated in 0.06708 seconds
