Home » Newcomers » Newcomers » java.io.FileInputStream Error
java.io.FileInputStream Error [message #134326] Thu, 02 February 2006 12:09
Originally posted by: collette.matthias.fmr.com
I am not sure if this is the best place to post this question, but as a
newcomer to eclipse I ficured I would start here.
I have installed Eclipse 3.1.2 along with the HP OpenView Plug-in for
VoiceXML.
When Validating code using the HP OpenView Plug-in, the following error
occurs:
First Element Error: java.io.FileInputStream\vc-5.0\vobs_vc\.... (The
system cannot find the path specified).
I have spoken with HP and they believe it is an Eclipse error with not
finding the file.
The project is connected to a network drive (V:) through Rational
ClearCase and I believe this is the issue. Is there something in Eclipse
that I need to set for the system to provide the absolute path to the
file? Or is this an HP Plug-in issue that I need to follow up with them?
Thank you,
Collette
Previous Topic:Print options
Next Topic:How to add a java source file into a java project?
Current Time: Sun Jul 27 11:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.27404 seconds
