Home » Eclipse Projects » Eclipse Platform » passing plugin classpath to a forked JVM
passing plugin classpath to a forked JVM [message #134293] Tue, 23 September 2003 08:55 Go to next message
Originally posted by: christian.sell.netcologne.de
I am launching a Java subprocess from within my plugin, and would like
to set the classpath of the forked VM to some of the same libraries that
are visible to my plugin. I am querying the plugin libraries with
plugin.getPluginDescriptor().getRuntimeLibraries(), and encounter the
following problems:
1. The plugin jar files are not accessible as disk file paths, but only
through URLs that use a custom protocol (platform:...).
2. At least during development, the plugin classes themselves are not
available as jar files at all.
Therfore my questions:
- is there a way to make the locations of the jar files from the plugin
install directory visible/readable for external programs, such as a
forked VM?
- (less important and likely) is there a way to externalize the location
of the compiled files used by eclipse during development
I would really like to get along without having to depend on or copy the
JDT code.. thanks in advance for any hints,
Christian
Re: passing plugin classpath to a forked JVM [message #134336 is a reply to message #134293] Tue, 23 September 2003 09:34 Go to previous messageGo to next message
to partly answer my own question:
for problem #1, Platform.resolve(url) is at least one step in the right
direction. Still not clear how to create a classpath from non-file-URLs,
though..
Christian Sell wrote:
> Hello,
> following problems:
> forked VM?
> Christian
Re: passing plugin classpath to a forked JVM [message #134347 is a reply to message #134293] Tue, 23 September 2003 09:40 Go to previous messageGo to next message
Try something like this:
IPluginDescriptor descriptor = Plugin.getDefault().getDescriptor();
ILibrary[] libraries = descriptor.getRuntimeLibraries();
URL installUrl = Platform.resolve(descriptor.getInstallURL());
for (int i = 0; i < libraries.length; ++i)
try
File file = libraries[i].getPath().toFile();
URL url = new URL(installUrl, file.toString());
// add the url to your forked VM classpath
catch (Exception e)
e.printStackTrace();
Chris
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:bkpfqs$304$1@eclipse.org...
> Hello,
> following problems:
> forked VM?
> Christian
Re: passing plugin classpath to a forked JVM [message #134358 is a reply to message #134293] Tue, 23 September 2003 09:41 Go to previous messageGo to next message
During development, you can point your forked VM to the bin
directory of your plugin Project (which is what PDE does too
when it launches a runtime workbench).
Chris
> Hello,
> following problems:
> forked VM?
> Christian
Re: passing plugin classpath to a forked JVM [message #134434 is a reply to message #134347] Tue, 23 September 2003 10:36 Go to previous messageGo to next message
thanks. Could you elaborate a little on what you mean by "add the url to
your forked VM classpath" - to my knowledge the classpath command line
option only accepts file system paths?
And while we're at it, how to I determine my plugin projects output
(bin) directory?
thanks,
Christian
> try
> catch (Exception e)
> Chris
>>Hello,
>>following problems:
>>forked VM?
>>Christian
Re: passing plugin classpath to a forked JVM [message #134782 is a reply to message #134293] Tue, 23 September 2003 22:00 Go to previous message
Originally posted by: bnfb.cs.washington.edu
Christian,
Here's how we solved the same issue (launching a Java subprocess and using
the same paths):
First, we read Darin Wright's article about launching Java subprocesses
( http://www.eclipse.org/articles/Article-Java-launch/launchin g-java.html).
Second, we build the classpath using conditionals to determine whether we
are in development model (running under the PDE) or in delivery mode (using
the plugin jar). Here's a fragment:
// Look for the compiled jar - this will exist if I am running in a plug-in
URL jar_url = plugin.find(new Path(MY_JAR_NAME));
if (jar_url != null) {
File jar = new File(jar_url.getPath());
if (jar.exists()) {
IPath path = new Path(jar_url.getPath());
IRuntimeClasspathEntry entry =
JavaRuntime.newArchiveRuntimeClasspathEntry(path);
classpath.add(urbansimEntry.getMemento());
} else {
// Look for the project bin directory - this will exist if I am running
under the PDE
// Note that we are looking for the project directory that is the source of
the plug-in
// that is running under the PDE, thus we look in "workspace/". If we did
not take off
// the last segment we would be looking in "runtime-workspace/" which is not
where
// the source code for *this* plug-in is.
File src = new File(
workspace
.getRoot()
.getLocation()
.removeLastSegments(1)
.toString()
+ "workspace/MyProject");
if (src.exists()) {
IPath path = new Path(src.getPath() + "/bin/");
classpath.add(entry.getMemento());
There are some obvious places where this solution could be cleaned up but
being a pragmatist, this works for me so the clean up will probably never
get time allocated. Improvements would be: (1) getting the MY_JAR_NAME from
the project build information rather than as a string constant; (2) getting
the project name from the project rather than using a string; (3) not
depending on the class file location being "/bin/"; (4) not depending on the
workspace directory being named "workspace".
Bjorn Freeman-Benson
Center for Urban Simulation and Policy Analysis (http://www.urbansim.org/)
Previous Topic:Headless eclipse app doesn't run when workspace missing
Next Topic:Eclipse *very very* slow to start on Redhat 9
Current Time: Wed Jul 16 22:08:23 EDT 2025
Powered by FUDForum. Page generated in 0.26712 seconds
