[ANN] <oXygen/> XML Editor 2.0.4 [message #134160] |
Tue, 23 September 2003 03:32 |
Originally posted by: george.oxygenxml.com
A new version of oXygen XML Editor (http://www.oxygenxml.com) is available
for download. The new features relevant for the Eclipse plugin added by
oXygen 2.0.4 are:
Saxon support - Now you can transform XML files using the Saxon transformer.
The user can choose between Xalan and Saxon when configuring the
transformation.
Improve the validate support for RelaxNG schemas - The Relax NG schemas in
Compact syntax can now be validated using <oXygen/>.
Content completion driven by Relax NG Schemas - When editing documents
associated with a Relax NG schema the editor will offer content completion
proposals for elements and attributes.
XML perspective and XML project support - The XML project and XML
perspective allows easy access to the new wizards provided by <oXygen/>.
Shortcuts for actions - Full configurable shortcuts for actions were
introduced in the Eclipse plugin. You can retrieve the <oXygen/> actions in
the Window->Preferences menu under Workbench->Keys dialog in the oXygen XML
Editor entry.
Indent/unindent selection in Eclipse plugin - Indent/unindent selection is
available now also for the Eclipse plugin. The default key bindings are: Tab
to indent and Shift+Tab to unindent.
Escape selection in Eclipse plugin - The Escape selection contextual menu
option was introduced also in the Eclipse plugin. This allows to XML escape
the selected content.
Import from HTML available in Eclipse - The Import HTML as XML feature is
now present in the Eclipse plugin.
<oXygen/> XML Editor can be freely evaluated for 30 days and it costs $74
($48 for academic use).
Best Regards,
George
George Cristian Bina mailto:george@sync.ro
Phone +40-(0)251-461480, +40-(0)251-461481
Fax +40-(0)251-461482
Mobile +40-(0)723-224067
SyncRO Soft srl, Bd N. Titulescu 170, Craiova, 1100 - Romania
http://www.sync.ro
<oXygen/> XML Editor - http://www.oxygenxml.com/
FUDForum. Page generated in 1.05892 seconds
