CDT and Refactoring Support [message #134125] |
Sun, 09 January 2005 15:23  |
Originally posted by: kdale.cs.virginia.edu
It looks like CDT supports simple refactoring (renaming) as of 2.0, based
on the docs that I've looked at, but the option doesn't appear when I try
to use it via the refactoring context menu. Instead I get "<no
refactoring available>". BTW, I'm using Eclipse 3.0.1 and CDT 2.1.0. Any
ideas?
Re: CDT and Refactoring Support [message #134889 is a reply to message #134225] |
Fri, 14 January 2005 10:32  |
Try doing it from the outline view context menu instead of from the editor.
-Andrew
"Kevin Dale" <kdale@cs.virginia.edu> wrote in message
news:cru7v0$8br$1@www.eclipse.org...
> BTW, I'm on WinXP. Based on help docs, it looks like I _should_ be able
> to right-click a class name in a C++ project header file and do a
> refactor-rename from there. Should I be able to do this, or is this not
> available yet either? Also, what is the approximate next release date?
> - Kevin
> johnc wrote:
> > The feature is significantly limited.
> > Different contributors are looking into upgrading this funcitonality for
our
> > next release.
> > JC
> > news:crs3rq$72r$1@www.eclipse.org...
based
try
Any
> >> ideas?
FUDForum. Page generated in 0.10394 seconds
