TPTP Agent Controller is not running [message #134113] |
Fri, 08 August 2008 10:18  |
I am trying to make TPTP work in windows. Has anybody managed to run Agent
Controller. When trying to start
AgentController\win_ia32\bin\ACServer.exe,
I am getting this exception
Error starting transport layers, Agent controller exiting.
See servicelog.log for error report.
This is the content of servicelog.log
<CommonBaseEvent creationTime="2008-08-08T14:02:43.218000Z"
globalInstanceId="A0054838FA5E43909BBF68900B7617DC" msg="Unable to create
named pipe." severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c,
line 1068" instanceId="1001" location="ankurshah" locationType="IPV4"
processId="4292" subComponent="Named Pipe TL" threadId="4436"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
globalInstanceId="AFC9EF99C45548FD9CB3F56EA2FAF92B" msg="An error was
returned from TransportLayer(1001)::startTransportLayer errNum = -1"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\agentController\ConnectionManager.c,
line 263" instanceId="2" location="ankurshah" locationType="IPV4"
processId="4292" subComponent="Connection Manager" threadId="4436"
</situation>
</CommonBaseEvent>
My environment is JDK5, Eclipse 3.3 and TPTP 4.4. Any inputs to solve this
problem will be greatly appreciated.
Re: TPTP Agent Controller is not running [message #134208 is a reply to message #134141] |
Mon, 11 August 2008 07:16  |
Please see the getting started instructions for the required
configuration/steps:
http://www.eclipse.org/tptp/home/downloads/installguide/Agen tController44.html
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:g7hm52$a1e$1@build.eclipse.org...
> You may have another Agent Controller running on the same machine already.
> Check to see if there is any ACServer.exe process running on the machine
> prior to starting any AC, also check to make sure there is no dangling
> java.exe that may have associated with the running ACServer.exe. If there
> is any, they have to be terminated also.
> Eugene
> "Ankur Shah" <ankur.shah@in.ibm.com> wrote in message
> news:2ccb642d6eb3c9ecf4843065eafa15e2$1@www.eclipse.org...
>>AgentController\win_ia32\bin\ACServer.exe, I am getting this exception
>> </situation>
>> </CommonBaseEvent>
>> </situation>
>> </CommonBaseEvent>
>> this problem will be greatly appreciated.
FUDForum. Page generated in 0.02701 seconds
