Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP Agent Controller is not running
TPTP Agent Controller is not running [message #134113] Fri, 08 August 2008 10:18 Go to next message
I am trying to make TPTP work in windows. Has anybody managed to run Agent
Controller. When trying to start
AgentController\win_ia32\bin\ACServer.exe,
I am getting this exception
Error starting transport layers, Agent controller exiting.
See servicelog.log for error report.
This is the content of servicelog.log
<CommonBaseEvent creationTime="2008-08-08T14:02:43.218000Z"
globalInstanceId="A0054838FA5E43909BBF68900B7617DC" msg="Unable to create
named pipe." severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c,
line 1068" instanceId="1001" location="ankurshah" locationType="IPV4"
processId="4292" subComponent="Named Pipe TL" threadId="4436"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
globalInstanceId="AFC9EF99C45548FD9CB3F56EA2FAF92B" msg="An error was
returned from TransportLayer(1001)::startTransportLayer errNum = -1"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\agentController\ConnectionManager.c,
line 263" instanceId="2" location="ankurshah" locationType="IPV4"
processId="4292" subComponent="Connection Manager" threadId="4436"
</situation>
</CommonBaseEvent>
My environment is JDK5, Eclipse 3.3 and TPTP 4.4. Any inputs to solve this
problem will be greatly appreciated.
Re: TPTP Agent Controller is not running [message #134141 is a reply to message #134113] Fri, 08 August 2008 10:43 Go to previous messageGo to next message
You may have another Agent Controller running on the same machine already.
Check to see if there is any ACServer.exe process running on the machine
prior to starting any AC, also check to make sure there is no dangling
java.exe that may have associated with the running ACServer.exe. If there is
any, they have to be terminated also.
Eugene
"Ankur Shah" <ankur.shah@in.ibm.com> wrote in message
news:2ccb642d6eb3c9ecf4843065eafa15e2$1@www.eclipse.org...
>Controller. When trying to start AgentController\win_ia32\bin\ACServer.exe,
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
Re: TPTP Agent Controller is not running [message #134208 is a reply to message #134141] Mon, 11 August 2008 07:16 Go to previous message
Please see the getting started instructions for the required
configuration/steps:
http://www.eclipse.org/tptp/home/downloads/installguide/Agen tController44.html
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:g7hm52$a1e$1@build.eclipse.org...
> is any, they have to be terminated also.
> Eugene
>>AgentController\win_ia32\bin\ACServer.exe, I am getting this exception
>> </situation>
>> </CommonBaseEvent>
>> </situation>
>> </CommonBaseEvent>
>> this problem will be greatly appreciated.
Previous Topic:TPTP4.5.0. Problem with org.eclipse.hyades.test.doc.user dependency
Next Topic:TPTP with Eclipse and RAD Issue
Current Time: Wed Jul 16 19:00:58 EDT 2025
Powered by FUDForum. Page generated in 0.04600 seconds
