Home » Eclipse Projects » Equinox » P2 Installer 3.5 final fails with "An error occurred while collecting items to be installed&quo
P2 Installer 3.5 final fails with "An error occurred while collecting items to be installed&quo [message #134020] Thu, 02 July 2009 19:34 Go to next message
--------------040907040907010806070304
This fails only with P2 Installer. The exact same scenario works with P2
Agent 3.5. It might be because my bundles are locally cached though.
What's more P2 Installer is freshly unzipped. First run. No History.
C
Re: P2 Installer 3.5 final fails with "An error occurred while collecting items to be installed [message #134258 is a reply to message #134020] Sat, 04 July 2009 08:55 Go to previous messageGo to next message
I posted a bug here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282427
> Cédric
Re: P2 Installer 3.5 final fails with "An error occurred while collecting items to be installed [message #134311 is a reply to message #134258] Sun, 05 July 2009 05:18 Go to previous message
Problem solved ! :)
Well, I decided to roll my sleeves up. After some investigation, I found
out what the problem was. It was a concurrency issue which made the
artifact repository end up being disabled upon artifact fetching.
Full details and a patch are available in the bug:
Kind regards,
Cédric
>> P2 Agent 3.5. It might be because my bundles are locally cached though.
>> Regards,
>> Cédric
Previous Topic:Starting a Java application from a bundle
Next Topic:Java application requirements
Current Time: Tue Jul 22 02:34:20 EDT 2025
Powered by FUDForum. Page generated in 0.05084 seconds
