Home » Modeling » TMF (Xtext) » [TCS] custom separators in KM3.tcs
[TCS] custom separators in KM3.tcs [message #12281] Thu, 17 April 2008 10:39 Go to next message
I noticed in KM3.tcs, there are custom separators declared in template
Package and Context:
"before_block_bracket" and "after_supertypes_coma"
however, in class org.eclipse.gmt.tcs.extractor.prettyPrinter in
serializeSeqElem(Object, Object), it seems these custom separators are
never considered. Are they obsolete?
Re: [TCS] custom separators in KM3.tcs [message #12292 is a reply to message #12281] Thu, 17 April 2008 11:41 Go to previous messageGo to next message
By definition, they are custom. So, you can define your own.
However, they need to be mapped to an implementation. For instance, you
can have a refining transformation that would transform
<before_block_bracket> into <space>. In this way, you separate the
presentation from the contents.
Note that we never actually experimented with this, but such a
transformation could be written quite quickly.
Frédéric Jouault
Re: [TCS] custom separators in KM3.tcs [message #12343 is a reply to message #12292] Mon, 21 April 2008 06:03 Go to previous messageGo to next message
Okay, but where are these defined? I mean, how does the extractor know
what to do with "after_supertypes_coma", if this is not specified in the
TCS, where else?
Re: [TCS] custom separators in KM3.tcs [message #12352 is a reply to message #12343] Mon, 21 April 2008 08:40 Go to previous message
>>> template Package and Context:
> TCS, where else?
The extractor ignores custom separators it does not know. So,
"after_supertypes_coma" actually means "nothing" if you do not transform
it to a supported separator.
If you want to give a different meaning than "nothing" to a custom
separator, you can for instance do this in an ATL transformation.
If you do not feel that separating the definition of a custom separator
from its actual implementation is necessary for a specific TCS model,
then you may directly use the predefined custom separator.
At the current time, "after_supertypes_coma" is defined as being
"nothing", which is the default, and does not require any additional
specification.
Frédéric Jouault
Previous Topic:Re: Xtext (4.3 beta) for EMF resources
Next Topic:[TCS] TCSRuntime doitForContext ambiguity
Current Time: Mon Jul 14 04:34:35 EDT 2025
Powered by FUDForum. Page generated in 0.05085 seconds
