Home » Eclipse Projects » Remote Application Platform (RAP) » theme not used when deployed to tomcat
theme not used when deployed to tomcat [message #134008] Mon, 25 May 2009 12:06 Go to next message
Hi all,
when I deploy my rap application on tomcat it works fine but my theme and
branding is not used. The theme directory is in the builded plugin so I
dont understand why it isnt used!?
Has somebody an answer?
best regars,
p-lex
Re: theme not used when deployed to tomcat [message #134010 is a reply to message #134008] Mon, 25 May 2009 12:39 Go to previous messageGo to next message
ok i found the thing that was wrong.
The servlet name in the branding definition was not the one on tomcat. Now
it works
How can I change the servlet name of the rap application? The default
value is "rap"
best regards
Re: theme not used when deployed to tomcat [message #134012 is a reply to message #134010] Mon, 25 May 2009 12:49 Go to previous message
> Now it works
> value is "rap"
> best regards
when you add a branding extension to your project
(org.eclipse.rap.ui.branding) you can change the servlet name in the
extension element details dialog on the right hand side of the wizard.
HTH
Christian
To reply to this posting directly use the following address and
remove the 'NO-SPAM' part: Riedel.Christian.NO-SPAM@gmx.net
Previous Topic:CTabFolder
Next Topic:could i build a wiki using RAP?
Current Time: Sat Jul 12 16:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.04378 seconds
