Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo map references in one table
Teneo map references in one table [message #133942] Tue, 10 March 2009 06:28 Go to next message
Hello Martin
We have a lot of references in our ecore model. Teneo creates for all the
'many' references a separated table.
Now is it some how possible to map all the references in one table?
Something like:
References(ObjectUUID, FeatureName, ReferenceUUID, Index, ObjectName,
ReferenceName)
('person uuid','roles','role uuid','index','person','role')
The references are always the same (non-containment, index ....).
Maybe there is some kind of hock in where I can change the mapping,
storing and reading of references?
Thanks for any info
Flavio
Re: Teneo map references in one table [message #133967 is a reply to message #133942] Tue, 10 March 2009 15:50 Go to previous messageGo to next message
Hi Flavio,
I don't know if this is possible (at least I don't know right away how to do this). With many, do you mean many-to-many
or one-to-many? For the latter you can set an option to prevent the default to use join tables (set the option:
PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS to false).
btw, support for Teneo is given on the main EMF newsgroup, which I added on the to.
gr. Martin
Flavio Donzé wrote:
> Hello Martin
> the 'many' references a separated table.
> Something like:
> ReferenceName)
> Thanks for any info
> Flavio
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo map references in one table [message #133980 is a reply to message #133967] Wed, 11 March 2009 04:57 Go to previous messageGo to next message
Hey Martin
Thanks for the information.
I tried the JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS option, not exactly
what I need. In my Person/Role connection the 'role' table is extended
with two new fields (person_roles_id and person_roles_idx).
I would like to have a global table for all references, so it would be
easier for us to check if an object has references and for reporting.
Is there a way to manipulate the mapping (without passing the mapping
file)?
org.hibernate.Interceptor won't help me in this case I guess.
Maybe extend or override some component?
cheers
Flavio
Martin Taal wrote:
> Hi Flavio,
the to.
> gr. Martin
> Flavio Donzé wrote:
>> Hello Martin
>> Something like:
>> ReferenceName)
>> Thanks for any info
>> Flavio
Re: Teneo map references in one table [message #133993 is a reply to message #133980] Wed, 11 March 2009 08:53 Go to previous messageGo to next message
Hi Flavio,
I have thought about this for a few hours... Hibernate uses the OneToManyPersister class to persist a one to many. But
afaics this one can not be customized (and it looks rather difficult to change). So the only thing I can come up with is
to look at implementing a custom hibernate UserType (see the hibernate manual) and map all EReferences using this
usertype and a common join table.
However, usertypes are mostly used for primitive values or external references. What I am not sure about is if you need
to implement cascade behavior manually (if even possible) if you use a usertype for an ereference.
Can you check the hibernate manual/internet to look for usertypes for associations?
Another option for you is to explicitly model the common join table and have it there next to the 'normal' references
between two objects. Then when the 'normal' reference is updated also the common joined object is updated and vice
versa. You can then prevent Teneo/hibernate from persisting the 'normal' references by making them transient.
gr. Martin
Flavio Donzé wrote:
> Hey Martin
> exactly what I need. In my Person/Role connection the 'role' table is
> extended with two new fields (person_roles_id and person_roles_idx).
> file)?
> cheers
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
>> to do
>> default
>> added on
> the to.
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hello Martin
>>> Something like:
>>> ReferenceName)
>>> Thanks for any info
>>> Flavio
The Netherlands
Re: Teneo map references in one table [message #134013 is a reply to message #133993] Mon, 16 March 2009 06:51 Go to previous messageGo to next message
Hi Martin
I searched the web and check my hibernate book. The best article I found
was that one: http://www.hibernate.org/122.html
The problem here is that Teneo does not support the @Any annotation
(http://www.elver.org/hibernate/ejb3_features.html).
In our software we can not provide the mapping file directly to hibernate.
Well I will do some more thinking, this issue is not so urgent to us. I
will notify you if I come up with a solution.
cheers
Flavio
Martin Taal wrote:
> Hi Flavio,
associations?
> gr. Martin
> Flavio Donzé wrote:
>> Hey Martin
>> file)?
>> cheers
>> Flavio
>> Martin Taal wrote:
>>> Hi Flavio,
>>> to do
>>> default
>>> added on
>> the to.
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> Hello Martin
>>>> Something like:
>>>> ReferenceName)
>>>> Thanks for any info
>>>> Flavio
Re: Teneo map references in one table [message #134014 is a reply to message #134013] Mon, 16 March 2009 07:07 Go to previous message
Hi Flavio,
For your info, actually Teneo uses the hibernate any type to map EReferences which point to EObject (and not to a
specific type). So the only thing missing here is the annotation to make it more controllable...
If you need it then feel free to enter a bugzilla for it.
gr. Martin
Flavio Donzé wrote:
> Hi Martin
> cheers
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
> associations?
>> and have
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hey Martin
>>> be easier for us to check if an object has references and for reporting.
>>> file)?
>>> cheers
>>> Flavio
>>> Martin Taal wrote:
>>>> Hi Flavio,
>>>> how to do
>>>> default
>>>> added on
>>> the to.
>>>> gr. Martin
>>>> Flavio Donzé wrote:
>>>>> Hello Martin
>>>>> all the 'many' references a separated table.
>>>>> Something like:
>>>>> ObjectName, ReferenceName)
>>>>> Thanks for any info
>>>>> Flavio
The Netherlands
Re: Teneo map references in one table [message #620716 is a reply to message #133942] Tue, 10 March 2009 15:50 Go to previous message
Hi Flavio,
gr. Martin
Flavio Donzé wrote:
> Hello Martin
> Something like:
> ReferenceName)
> Thanks for any info
> Flavio
The Netherlands
Re: Teneo map references in one table [message #620718 is a reply to message #133967] Wed, 11 March 2009 04:57 Go to previous message
Hey Martin
file)?
cheers
Flavio
Martin Taal wrote:
> Hi Flavio,
the to.
> gr. Martin
> Flavio Donzé wrote:
>> Hello Martin
>> Something like:
>> ReferenceName)
>> Thanks for any info
>> Flavio
Re: Teneo map references in one table [message #620720 is a reply to message #133980] Wed, 11 March 2009 08:53 Go to previous message
Hi Flavio,
gr. Martin
Flavio Donzé wrote:
> Hey Martin
> file)?
> cheers
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
>> to do
>> default
>> added on
> the to.
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hello Martin
>>> Something like:
>>> ReferenceName)
>>> Thanks for any info
>>> Flavio
The Netherlands
Re: Teneo map references in one table [message #620725 is a reply to message #133993] Mon, 16 March 2009 06:51 Go to previous message
Hi Martin
cheers
Flavio
Martin Taal wrote:
> Hi Flavio,
associations?
> gr. Martin
> Flavio Donzé wrote:
>> Hey Martin
>> file)?
>> cheers
>> Flavio
>> Martin Taal wrote:
>>> Hi Flavio,
>>> to do
>>> default
>>> added on
>> the to.
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> Hello Martin
>>>> Something like:
>>>> ReferenceName)
>>>> Thanks for any info
>>>> Flavio
Re: Teneo map references in one table [message #620726 is a reply to message #134013] Mon, 16 March 2009 07:07 Go to previous message
Hi Flavio,
gr. Martin
Flavio Donzé wrote:
> Hi Martin
> cheers
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
> associations?
>> and have
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hey Martin
>>> file)?
>>> cheers
>>> Flavio
>>> Martin Taal wrote:
>>>> Hi Flavio,
>>>> how to do
>>>> default
>>>> added on
>>> the to.
>>>> gr. Martin
>>>> Flavio Donzé wrote:
>>>>> Hello Martin
>>>>> Something like:
>>>>> Thanks for any info
>>>>> Flavio
The Netherlands
Previous Topic:[EMF Compare] How to start
Next Topic:[EMF Compare] ClassCastException in save action and some diff meta model questions
Current Time: Tue Jul 15 13:03:08 EDT 2025
Powered by FUDForum. Page generated in 0.05410 seconds
