Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Merging multiple EMF editors
Merging multiple EMF editors [message #133673] |
Fri, 27 February 2009 14:19  |
Originally posted by: anders.opendev.se
I am not entirely experienced in the world of EMF yet but I'm slowly
getting acquainted, so please go easy on me.
I'm working with a project that has a multitude of plugins generated from
a set of different EMF models. Some of them have references to others (is
this the right terminology?)
Anyway, the major part of the models have generated *.Edit and *.Editor
plugins. The thing is that I would like to merge/write a single editor
for all models. Now I am facing some difficulties because I don't fully
understand the underlying mechanisms yet.
My thinking goes as follows:
1. I remove all the *.Editor plugins and write a general plugin based on
one of the existing editors. (But how do I accommodate for all different
aspects of the models? E.g. specific object types should be show in the
outline view depending on what model is edited. Is it possible to use
reflection somehow?)
2. I also want a single EditingDomaing for all models. How do I
accomplish this? Is there any pitfalls by simply having a "singleton"
EditingDomain?
3. To "hook up" the existing models to the new editor - what is needed?
Is it necessary to write some kind of small "wrapper/proxy" editors that
instantiate the "one and only" editor? Or how should I go about this? Is
there any settings where one can specify which editor to use?
4. Is the above approach doable or is there any better/easier way?
Thank you so much for you time!
BR,
Anders
Re: Merging multiple EMF editors [message #133691 is a reply to message #133673] |
Fri, 27 February 2009 14:56   |
--------------090305030608050908060900
Content-Type: text/plain; charset=UTF-8; format=flowed
Anders,
Comments below.
I'll refrain from calling you a loser until later. Although if you
haven't bought the EMF book yet, I might still need to berate you. :-P
Yep.
If you look at the editors, you'll see they almost all look alike...
You'll want to look at this article:
< http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html>
> EditingDomain?
Normally each editor has it's own editing domain. It's far tricker to
figure out how to share them...
You'll likely be surprised that it just works. That's because the
ComposedAdapterFactory that's created uses a registry to find the item
providers for whatever object happens to show up in the editor.
Probably you'll find you can just pick one of the editors (the one for
the "base" model) and it will be able to work nicely with all the
models, especially if you do that extensible child creation thing from
my blog...
> BR,
> Anders
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Anders,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:go9ebd$o3u$1@build.eclipse.org" type="cite">
<pre wrap="">I am not entirely experienced in the world of EMF yet but I'm slowly
</pre>
</blockquote>
haven't bought the EMF book yet, I might still need to berate you. :-P<br>
<pre wrap="">
</pre>
</blockquote>
Yep.<br>
<pre wrap="">
</pre>
</blockquote>
If you look at the editors, you'll see they almost all look alike...<br>
<pre wrap="">
</pre>
</blockquote>
You'll want to look at this article:<a
href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html"><br>
</a>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html"> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html</a><br>
</blockquote>
<pre wrap="">
EditingDomain?
</pre>
</blockquote>
figure out how to share them...<br>
<pre wrap="">
</pre>
</blockquote>
providers for whatever object happens to show up in the editor.<br>
<pre wrap="">
</pre>
</blockquote>
my blog...<br>
<pre wrap="">
BR,
Anders
</pre>
</blockquote>
</body>
</html>
--------------090305030608050908060900--
Re: Merging multiple EMF editors [message #133704 is a reply to message #133691] |
Fri, 27 February 2009 15:18   |
Thanks for your reply!
See comments below.
Den Fri, 27 Feb 2009 14:56:16 -0500 skrev Ed Merks:
Thanks, you don't know how much that means to me ;-)
And yes, I have bought the book!
Yes I know. And I have already written some common code/classes that they
all use to modify the behaviour of the editors. So there wouldn't be much
work on actually making them into one single editor. I think it would be
quite straight forward. My concern lies in that I'm sensing that I am
missing some important pieces of the puzzle...
know.html
Thanks a lot. That looks promosing!
>> EditingDomain?
Ok, do you know anything about this? Because this will becoming a major
issue since we plan on using CDO for the models and if I have my sources
right CDO requires the models to share EditingDomain... But then again, I
could be wrong, it has happened before :-/
>> that instantiate the "one and only" editor? Or how should I go about
>> this? Is there any settings where one can specify which editor to use?
Ok, I think I understand this. I can feel that there is some problem
lurking here but I will take your word for it for now.
> my blog...
Yes, I was hoping that this would be the case.
Again, thanks for your response and insights!
Re: Merging multiple EMF editors [message #133717 is a reply to message #133704] |
Fri, 27 February 2009 15:47   |
--------------000406030309050000070407
Anders,
Start by assuming you can get by with an editing domain per editor and
see how far that gets you first. If you need more than that, you'll
want to start to look into the Transaction stuff.
It's best to the EMF newsgroup for future questions about EMF:
news://new.eclipse.org/eclipse.tools.emf
> See comments below.
> know.html
>>> EditingDomain?
>> my blog...
<html>
<head>
</head>
Anders,<br>
<br>
want to start to look into the Transaction stuff.<br>
<br>
It's best to the EMF newsgroup for future questions about EMF:<br>
<blockquote><a href="news://new.eclipse.org/eclipse.tools.emf">news://new.eclipse.org/eclipse.tools.emf</a><br>
</blockquote>
<br>
<blockquote cite="mid:go9hqf$o3u$2@build.eclipse.org" type="cite">
<pre wrap="">Thanks for your reply!
See comments below.
</pre>
<blockquote type="cite">
<pre wrap="">I'll refrain from calling you a loser until later. Although if you
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">Anyway, the major part of the models have generated *.Edit and *.Editor
</pre>
</blockquote>
<pre wrap="">If you look at the editors, you'll see they almost all look alike...
</pre>
</blockquote>
</pre>
<pre wrap="">You'll want to look at this article:
<a class="moz-txt-link-freetext" href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt"> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt</a>-
</pre>
</blockquote>
<pre wrap=""><!---->know.html
</pre>
<pre wrap="">2. I also want a single EditingDomaing for all models. How do I
EditingDomain?
</pre>
</blockquote>
<pre wrap="">Normally each editor has it's own editing domain. It's far tricker to
</pre>
</blockquote>
</pre>
<pre wrap="">3. To "hook up" the existing models to the new editor - what is needed?
</pre>
</blockquote>
<pre wrap="">You'll likely be surprised that it just works. That's because the
</pre>
</blockquote>
</pre>
<pre wrap="">4. Is the above approach doable or is there any better/easier way?
</pre>
</blockquote>
<pre wrap="">Probably you'll find you can just pick one of the editors (the one for
my blog...
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------000406030309050000070407--
Re: Merging multiple EMF editors [message #133742 is a reply to message #133729] |
Sat, 28 February 2009 01:24  |
Den Sat, 28 Feb 2009 05:38:36 +0100 skrev Eike Stepper:
>> sources right CDO requires the models to share EditingDomain... But
>> then again, I could be wrong, it has happened before :-/
> No such requirement is imposed by CDO. CDO integrates with EMF directly
> on the model layer.
That's good news, thanks for the information!
BR,
Anders
Re: Merging multiple EMF editors [message #620693 is a reply to message #133673] |
Anders,
Comments below.
Yep.
> EditingDomain?
my blog...
> BR,
> Anders
<html>
<head>
</head>
Anders,<br>
<br>
Comments below.<br>
<br>
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
Yep.<br>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</a>
<blockquote><a
</blockquote>
<pre wrap="">
EditingDomain?
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
my blog...<br>
<pre wrap="">
BR,
Anders
</pre>
</blockquote>
</body>
</html>
Re: Merging multiple EMF editors [message #620694 is a reply to message #133691] |
See comments below.
know.html
>> EditingDomain?
> my blog...
Re: Merging multiple EMF editors [message #620695 is a reply to message #133704] |
Anders,
> See comments below.
> know.html
>>> EditingDomain?
>> my blog...
<html>
<head>
</head>
Anders,<br>
<br>
<br>
</blockquote>
<br>
See comments below.
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
EditingDomain?
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
my blog...
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: Merging multiple EMF editors [message #620696 is a reply to message #133704] |
Fri, 27 February 2009 23:38  |
Anders,
Comments below...
on the model layer.
Editing domains reside in an EMF layer above the model layer (generated
model code) so I would say models are generally unaware of editing
domains. There may be upstream references at runtime in the form of
adapters, but these should not force you into any particular model design.
Cheers
/Eike
Re: Merging multiple EMF editors [message #620697 is a reply to message #133729] |
> on the model layer.
BR,
Anders
Current Time: Sun Aug 31 21:03:26 EDT 2025
Powered by FUDForum. Page generated in 0.05255 seconds
