cdt.ui problem [message #133607] |
Wed, 05 January 2005 14:53 |
Originally posted by: jwu100.gmail.com
I am using the eclipse with cdt 2.0.1 package on Solaris 2.9. I always get
errors when I start to use eclipse, although the program running ok.
Error messages:
The command 'org.eclipse.cdt.ui.edit.text.c.add.include' is not defined,
but is being asked if it is active. Are you using an actionDefinitionId
without defining a command?
Reason:
The command is undefined
The command 'org.eclipse.cdt.ui.edit.text.c.toggle.presentation' is not
defined, but is being asked if it is active. Are you using an
actionDefinitionId without defining a command?
Reason:
Unable to find Action Set: org.eclipse.cdt.ui.CFolderActionSet
Reason:
I tried to update everything, but cannot get it work.
Anyone know the solution for this?
wjs
FUDForum. Page generated in 0.03508 seconds
