Home » Language IDEs » ServerTools (WTP) » JBuilder to EClipse
JBuilder to EClipse [message #12235] Thu, 08 January 2004 10:50 Go to next message
Originally posted by: ALin.doe.state.nj.us
I have a project in JBuilder 7 and would like to migrate into
EClipse 3. After copying the folder into EClipse workspace,
what should I do next ?
Alex Lin
Re: JBuilder to EClipse [message #12237 is a reply to message #12235] Thu, 08 January 2004 11:35 Go to previous messageGo to next message
Originally posted by: nospam.cops.net
Hi!
First of all, this kind of questions are more appropiate for the
eclipse.platform newsgroup.
Second of all, you can import the project. Just go to File->Import, then
choose File system. Then, point to the directory that contains the
project, and from there it is pretty straightforward.
Stelian Iancu
"They say we are thinking in bits ..."
Alex Lin wrote:
> Alex Lin
Re: JBuilder to EClipse [message #12441 is a reply to message #12237] Fri, 09 January 2004 03:53 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Stelian Iancu wrote:
> Hi!
> then choose File system. Then, point to the directory that contains
> the project, and from there it is pretty straightforward.
> Stelian Iancu
> Alex Lin wrote:
Given the fact that you already copied it into the workspace you can
also try to directly create the Java project using New > Java Project.
The wizard is smart and tries to correctly setup your Java build path.
Dani
>> Thanks,
>> Alex Lin
Re: JBuilder to EClipse [message #12646 is a reply to message #12235] Mon, 12 January 2004 13:42 Go to previous message
As JBuilder is a very common IDE, I believe that it would be a good Idea to
let Eclipse open JBuilder projects: they are all xml files (.library also).
I think this could be a way to promote Eclipse diffusion.
Mostly people are scared to switch ide, in other cases "companies imposes a
specific IDE": enabling Eclipse to "convert" projects from other IDE could
be a good policy, or, better to work with other IDE files. In this way
programmers could be free to work with eclipse and mantain the projects file
updated for other people in the team that use JBuilder instead (and project
managers cannot say nothing about this anarky)
Luigi.
Previous Topic:NetBeans integrated in Eclipse?
Next Topic:Eclipse 3.0M6 Debugger not working with sysdeo tomcat plugin.
Current Time: Fri Aug 08 02:08:07 EDT 2025
Powered by FUDForum. Page generated in 0.03150 seconds
