Home » Language IDEs » ServerTools (WTP) » Web services client
Web services client [message #133264] Wed, 17 August 2005 11:07 Go to next message
Originally posted by: lf_killspam.hemmis.be
I am trying to follow the webservices client tutorial on the eclipse wtp
website, but can't even make it through step 2.
I am supposed to Open 'File -> New -> Other... -> Web Services -> Web
Service Client', but the option 'Web Services' only contains the option
'WSDL'. The option 'Web Service Client' is nowhere to be found.
I am using Eclipse 3.1 with wtp 0.7 (final). I have succesfully used the
wtp to work with ejb's, xml and xsd files, so I suppose it is correctly
installed.
Should I install any additional plug-ins to work with webservices, or
enable some options? The tutorials do not really seem to mention any
other prerequisites but the wtp plug-in itself.
Thank you for your suggestions.
Re: Web services client [message #133303 is a reply to message #133264] Wed, 17 August 2005 11:55 Go to previous messageGo to next message
Although there are no other requirements to work with Web services you may
have a problem with your install as you should see other entries under the
Web services heading. Are there any entries in your .log file
(WORKSPACE/.metadata/.log) that give any hints to problems?
Lawrence
Re: Web services client [message #133473 is a reply to message #133303] Thu, 18 August 2005 03:16 Go to previous message
There are no error messages in the log files. So I reinstalled the whole
wtp package including all prerequisites, but nothing changed. Still no
'Web service client' option available under 'new/other/web services'.
I am using JBoss 4.0.2 as server, and I read on a newsgroup that JBoss
4.0.2 is not supported to create Web service client, so I tried with
Geronimo 1.0 and Tomcat 5.5, but still no luck. I really don't get it.
What server definition should I use to make this work? Or am I totally
missing something here.
If anyone has a clue or had similar problems, please give me a hint.
Thanks a lot.
> Lawrence
Previous Topic:Servlets not going "live" on server without full rebuild
Next Topic:Adding support for mixed content in xml
Current Time: Fri Jul 25 14:03:47 EDT 2025
Powered by FUDForum. Page generated in 0.03477 seconds
