Home » Language IDEs » Java Development Tools (JDT) » Unable to Start Eclipse ( New to Eclipse)
Unable to Start Eclipse ( New to Eclipse) [message #133258] Sun, 11 January 2004 21:22 Go to next message
Originally posted by: yvramj.yahoo.com
I am not able to start eclipse. I loaded it on Windows 98. I have Java
j2sdk1.4.2_03 on my mechine. I am getting the following error.
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jan 11, 2004 19:52:28.410
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:437)
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Please let me know where I am going wrong.
Ram.
Re: Unable to Start Eclipse ( New to Eclipse) [message #133297 is a reply to message #133258] Mon, 12 January 2004 03:23 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Ram wrote:
>Hi,
Which version? Did you read the FAQ?
Dani
>!SESSION
>!STACK
>Thanks,
>Ram.
Re: Unable to Start Eclipse ( New to Eclipse) [message #133391 is a reply to message #133297] Mon, 12 January 2004 07:19 Go to previous messageGo to next message
Daniel Megert wrote:
> Ram wrote:
> >Hi,
> Dani
> >!SESSION
> >!STACK
> >Thanks,
> >Ram.
The Eclipse version is 3.0M6. I downloaded eclipse-SDK-3.0M6. I went
through
the FAQ. But I couln't fine any related problem.
Ram
Re: Unable to Start Eclipse ( New to Eclipse) [message #133463 is a reply to message #133391] Mon, 12 January 2004 08:44 Go to previous messageGo to next message
>>Ram wrote:
>>>Hi,
>>Dani
>>>!SESSION
>>>!STACK
>>>Thanks,
>>>Ram.
>through
Are you sure the right VM is taken i.e. do you start eclipse using -vm ...?
Dani
>Thanks,
>Ram
Re: Unable to Start Eclipse ( New to Eclipse) [message #133798 is a reply to message #133463] Mon, 12 January 2004 20:08 Go to previous messageGo to next message
> >>Ram wrote:
> >>>Hi,
> >>Dani
> >>>!SESSION
> >>>!STACK
> >>>Thanks,
> >>>Ram.
> >through
> Dani
I am not sure about this. I think this might be my problem. How di I
specify that and where do I have to do that ? Please let me know.
> >Thanks,
> >Ram
Re: Unable to Start Eclipse ( New to Eclipse) [message #133825 is a reply to message #133798] Mon, 12 January 2004 20:47 Go to previous messageGo to next message
> > Dani
http://www.eclipse.org/eclipse/faq/eclipse-faq.html#users_3
Re: Unable to Start Eclipse ( New to Eclipse) [message #133891 is a reply to message #133825] Mon, 12 January 2004 22:39 Go to previous messageGo to next message
> > > Dani
My JAVA is in C:\j2sdk 1.4.2_03 and Eclipse in C:\Eclipse\eclipse.exe.
I tried to start eclipse as
C:\Eclipse\eclipse.exe -VM C:\j2sdk1.4.2_03\jre\bin\javaw.exe
and also as
C:\Eclipse\eclipse.exe -VM C:\j2sdk1.4.2_03\bin\javaw.exe
It is still giving the same error.
Re: Unable to Start Eclipse ( New to Eclipse) [message #134119 is a reply to message #133891] Tue, 13 January 2004 04:20 Go to previous messageGo to next message
>>>>Dani
>and also as
Another problem might be that you did not download the full SDK or that
the download is corrupt. Please try again. I suggest to download 3.0 M6:
http://fullmoon.torolab.ibm.com/downloads/drops/S-3.0M6-2003 12182000/download.php?dropFile=eclipse-SDK-3.0M6-win32.zip
Dani
Re: Unable to Start Eclipse ( New to Eclipse) [message #134226 is a reply to message #133891] Tue, 13 January 2004 11:03 Go to previous messageGo to next message
> and also as
Have you tried the correct spelling (lowercase "-vm", not "-VM")?
Markus
Re: Unable to Start Eclipse ( New to Eclipse) [message #134798 is a reply to message #134226] Wed, 14 January 2004 19:43 Go to previous messageGo to next message
Markus Keller wrote:
> Ram wrote:
> > My JAVA is in C:j2sdk 1.4.2_03 and Eclipse in C:Eclipseeclipse.exe.
> > C:Eclipseeclipse.exe -VM C:j2sdk1.4.2_03jrebinjavaw.exe
> > and also as
> > C:Eclipseeclipse.exe -VM C:j2sdk1.4.2_03binjavaw.exe
> Markus
I deleted Eclipse and loaded it again. But still I am getting the same
error.
If I try to start Eclipse with out -vm command it is giving the error
" could not open 'C:\Program Files\Java\j2re1.4.2_03\lib\i386\jvm.cfg ".
If I try to start with vm like " C:\Eclipse\eclipse.exe -vm
c:\j2sdk1.4.2_03\bin\javaw.exe " it is writing error to log file. It not
finding JVM in correct location. JVM is in
C:\j2sdk1.4.2_03\jre\lib\jvm.cfg. I don't know where to make the change to
look there. Please help me.
Ram.
Re: Unable to Start Eclipse ( New to Eclipse) [message #134931 is a reply to message #134798] Thu, 15 January 2004 08:24 Go to previous messageGo to next message
>>>and also as
>>Markus
> error.
> Ram.
Hi Ram,
I had exactly the same problem with exactly the same versions (and
beeing a newbe too). In my case, checking the 'use folder names' box
during unzip soved the problem. Hope it works for you too.
Pawel
Re: Unable to Start Eclipse ( New to Eclipse) [message #134957 is a reply to message #134931] Thu, 15 January 2004 08:15 Go to previous messageGo to next message
> >>>and also as
> >>Markus
> > error.
> > " could not open 'C:Program FilesJavaj2re1.4.2_03libi386jvm.cfg ".
> > If I try to start with vm like " C:Eclipseeclipse.exe -vm
> > c:j2sdk1.4.2_03binjavaw.exe " it is writing error to log file. It not
> > C:j2sdk1.4.2_03jrelibjvm.cfg. I don't know where to make the change to
> > Thanks,
> > Ram.
> Hi Ram,
> Regards
> Pawel
Excellent Powel..! It worked great. Thank for your help.
Thank you all for your suggestions.
Ram.
Re: Unable to Start Eclipse ( New to Eclipse) [message #136923 is a reply to message #134957] Fri, 23 January 2004 22:26 Go to previous message
Ram wrote:
I got one of my old projects into Eclipse and trying run it.
I am getting errors while bulding the project like
" The declared package does not match the expected package COM.EMP.BEAN ".
I am not sure these error may be because of JRE settings. I went thru the
manual and my settings are good. When I did Window--> preferences-->
Java-->
installed JREs, it is showing the c:\J2SDK1.4.2_03 as the standard VM. I
am not sure if I need any more JREs to be installed. Can any one please
help me
what would be the wrong ?
Ram.
> > >>>and also as
> > >>Markus
> > > error.
> > > Thanks,
> > > Ram.
> > Hi Ram,
> > Regards
> > Pawel
> Ram.
Previous Topic:breakpoints in core classes. M6 regression?
Next Topic:How can I query current installed plugin?
Current Time: Sun Jul 27 06:08:04 EDT 2025
Powered by FUDForum. Page generated in 0.07545 seconds
