SVG support in charting engine [message #4] |
Tue, 24 August 2004 17:49  |
Originally posted by: me.sunnychan.org.uk
Is the charting engine going to support SVG? is it going to be new code
or we would take a current open source charting engine as the base?
Sunny Chan
Re: SVG support in charting engine [message #9237 is a reply to message #15] |
Tue, 22 February 2005 18:18   |
Originally posted by: jdixon.pentaho.com
FOP has support for SVG and there are many applications that output SVG. Is
there a way in BIRT to embed SVG so that any SVG producing application,
including chart engines, could be integrated easily.
From the charting side, we are looking for PNG / JPG / GIF for HTML output
(with image maps if possible) and SVG for PDF output. Output to MS Office
format documents (doc and xls) would be really good as well.
"Mark Coggins" <mcoggins@actuate.com> wrote in message
news:cglfhd$1os$1@eclipse.org...
> Hi Sunny,
> We are currently looking at various options here and are interested in
> feedback. In general, the bulk of BIRT is going to be new code designed
> from
> the outset to meet the needs of the Eclipse developer -- however we
> clearly
> want to leverage existing code wherever we can and charting is one of the
> areas where we may be able to do that. We do have a charting package that
> we
> are considering donating, but we are not sure it would be the best fit for
> the needs of the project.
> An interesting aspect of the charting project is that while we clearly
> need
> rich charting capabilities for reporting, I expect that it will be of
> general interest in other areas. We will need to pay attention to make
> sure
> that we leverage charting work across the Eclipse projects.
> What has been your experience with any open source charting out there? Any
> recommendations that we should look at?
> How are you looking to use the charting code? What sort of APIs would you
> need? What type of output formats?
> Mark
> "Sunny Chan" <me@sunnychan.org.uk> wrote in message
> news:cggcv5$u6t$1@eclipse.org...
>> Hello,
>> Thanks,
>> Sunny Chan
FUDForum. Page generated in 0.09278 seconds
