Home » Archived » BIRT » Trouble installing EMF
Trouble installing EMF [message #12178] Wed, 02 March 2005 20:08 Go to next message
Originally posted by: webmaster.armfinance.com
I've tried many times installing EFM but I always get this error.
"An exception occured while downloading feature from
http://update.eclipse.org/updates/3.0/features/org.eclipse.e mf.doc_2.0.1.jar"
I need to have it install because it is one of the required plugin of
BIRT. please help! :)
Re: Trouble installing EMF [message #12910 is a reply to message #12178] Thu, 03 March 2005 01:01 Go to previous messageGo to next message
Hi Jag,
How did you attempt to download and install EMF?
'EMF & SDO RT 2.0.1' is needed to build and use BIRT charts.
Try downloading this directly from:
http://eclipse.mirrors.tds.net/tools/emf/downloads/drops/2.0 .1/R200409171617/emf-sdo-runtime-2.0.1.zip
OR
ftp://ftp.cse.buffalo.edu/pub/Eclipse/tools/emf/downloads/dr ops/2.0.1/R200409171617/emf-sdo-runtime-2.0.1.zip
Note: These URLs were listed at the EMF download page at:
http://download.eclipse.org/tools/emf/scripts/downloads.php
Shut down your Eclipse 3.x instance (if it is running). Extract the
contents ('use folder names' during extraction) under your eclipse home
(plugins/features) folder and restart Eclipse.
If you still run into problems, consider posting your query at the EMF
newsgroups that may be accessed at:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.emf
Rohit Colaco
ECE Project Lead
Re: Trouble installing EMF [message #12995 is a reply to message #12910] Thu, 03 March 2005 03:37 Go to previous message
Thnaks Rohit
Ok. I have install it and its already running. One of the package or
component of EMF particularly the org.eclipse.emf.doc_2.0.1.jar couldn't
be downloaded. I don't know the reason. I exluded it from the list and
now it's working fine. What problem will I get if i dont install that
component?
Rohit Colaço wrote:
> Hi Jag,
> OR
> Rohit Colaco
> ECE Project Lead
Previous Topic:Having trouble installing BIRT
Next Topic:Oracle
Current Time: Sat Oct 25 03:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.04562 seconds
