Home » Eclipse Projects » DSDP - Target Management » RFE: Local terminal
RFE: Local terminal [message #12118] Wed, 11 July 2007 18:55 Go to next message
Hi all,
Before of all, I really like this project and congrats all of you to
provide these useful tools.
It would be great if we can get a local terminal, I'm a Linux guy and
like many Linux guys I like to work in the console for both stuffs, so
is there a plan to and a local Linux terminal? If no are you open for
such contribution? (I don't have time for for this for the moment but I
can put that on my too long todo list :-), if it's needed)
Alphonse
Re: Request TM Local terminal [message #12167 is a reply to message #12118] Thu, 12 July 2007 10:38 Go to previous messageGo to next message
Hello Alphonse,
we've had the request for a Terminal connected to the Local
Shell before on the Mailing List, see
http://dev.eclipse.org/mhonarc/lists/dsdp-tm-dev/msg01259.ht ml
Unfortunately it didn't make its way into bugzilla yet, so I'd
appreciate if you could file an enhancement request. Some help for
implementing a "Local" Terminal connector is also on
http://dev.eclipse.org/newslists/news.eclipse.dsdp.tm/msg001 85.html
As mentioned on the mailing list message above, Wicked Shell is an
alternative you can use for a local shell, although it does not provide
a Terminal. Of course you can also connect to the local host via Telnet
or SSH - but I agree that a "real" local connection would be preferable.
For future collaboration with Wicked Shell, see
http://wiki.eclipse.org/index.php/TM_Future_Planning
The other approach which would involve RSE is using the existing RSE
"Local" subsystem and replace the Command View with a Terminal, perhaps
doing so optionally. This request is already covered in bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=170910
Contributions for either the one or the other approach would be more
than welcome!
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Alphonse Van Assche wrote:
> Hi all,
> Cheers,
> Alphonse
Re: Request TM Local terminal [message #12891 is a reply to message #12167] Thu, 12 July 2007 11:53 Go to previous message
Martin Oberhuber a écrit :
> Hello Alphonse,
Done -> https://bugs.eclipse.org/bugs/show_bug.cgi?id=196337
At this time I use the SSH connector for that purpose but yes it would
be great if there is a local one.
That would be nice too, personally I prefer a terminal because of the
fact that there isn't command completion with a command view.
> than welcome!
At first view, implementing a Local Terminal require some knowledge of
the Terminal API and I don't have many time at the moment to spent in
that but when I find the time for it I would happily make such contribution.
Alphonse
Re: Request TM Local terminal [message #568858 is a reply to message #12118] Thu, 12 July 2007 10:38 Go to previous message
Hello Alphonse,
than welcome!
Martin Oberhuber
> Hi all,
> Cheers,
> Alphonse
Re: Request TM Local terminal [message #568913 is a reply to message #12167] Thu, 12 July 2007 11:53 Go to previous message
> Hello Alphonse,
> than welcome!
Alphonse
Previous Topic:Old HP NetBeans plug-in
Next Topic:Does TM and the Terminal view support a nested and heterogenous connection?
Current Time: Tue Jul 22 12:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.04120 seconds
