Home » Eclipse Projects » Orbit » Orbit and Software Updates on Eclipse 3.4 M6
Orbit and Software Updates on Eclipse 3.4 M6 [message #12112] Mon, 28 April 2008 09:15 Go to next message
Opening the "Software Updates" on Eclipse 3.4M6 causes the following Problem when Orbit has been installed (I have been testing it with several versions up to S20080427194908):
An internal error occurred during: "Fetching children of Known Repositories".
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepositoryFactory cannot be cast to org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.IMetadataRepositoryFactory
Johannes Weberhofer
Re: Orbit and Software Updates on Eclipse 3.4 M6 [message #12125 is a reply to message #12112] Tue, 29 April 2008 23:35 Go to previous messageGo to next message
On Mon, 28 Apr 2008 09:15:26 -0400, Johannes Weberhofer <office@weberhofer.at> wrote:
> Opening the "Software Updates" on Eclipse 3.4M6 causes the following Problem when Orbit has beeninstalled ....
This would be worth a very quick bug against Equinox/P2 (doesn't sound like an Orbit problem, per se).
But, M6 was so so long ago in P2-time, I'd recommend you see if it's still reproducible with the latest platform I-build (and the latest Orbit S build).
Thanks!
Re: Orbit and Software Updates on Eclipse 3.4 M6 [message #12137 is a reply to message #12125] Mon, 05 May 2008 09:05 Go to previous message
> Thanks!
You were right - no more errors on 3.4M7.
Thank you!
Johannes
Re: Orbit and Software Updates on Eclipse 3.4 M6 [message #563475 is a reply to message #12112] Tue, 29 April 2008 23:35 Go to previous message
Thanks!
Re: Orbit and Software Updates on Eclipse 3.4 M6 [message #563493 is a reply to message #12125] Mon, 05 May 2008 09:05 Go to previous message
> Thanks!
Thank you!
Johannes
Previous Topic:Orbit and Software Updates on Eclipse 3.4 M6
Next Topic:CXF Apache in Orbit?
Current Time: Fri May 09 10:18:54 EDT 2025
Powered by FUDForum. Page generated in 0.08265 seconds
