Home » Archived » Visual Editor (VE) » UI Windows do not show up anymore...
UI Windows do not show up anymore... [message #132382] Sat, 21 October 2006 19:42 Go to next message
Originally posted by: harel.ben-attia.comverse.com
Hi all,
My UI windows stopped showing....
When i open a visual class, the "Loading" window appears for a few seconds,
and then i can see "sShell" and "this" as icons, but no actual window is
appearing...
This happens for all my visual classes, and cleaning the project does not
help. Looking at the log file, no error is written.
Using:
Eclipse SDK 3.2
EMF SDK 2.2.0
Graphical Editing Framework SDK 3.2.0
J2EE Standard Tool Project 1.5.0
Java EMF Model SDK 1.2.0
Visual Editor 1.2.0
Web Standard Tools Project 1.5.0
No new installations or anything like that. The trigger for this is probably
a total Eclipse crash i had. The first exceptions in the log file after the
crash are below.
Thanks a lot in advance,
RL
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-21 06:36:52.156
!MESSAGE Exception thrown.
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2511)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2439)
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1929)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1833)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1768)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1576)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:876)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:854)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:626)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:330)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1693)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1089)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1134)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.jem.proxy 2 0 2006-10-21 06:37:31.296
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption-- Error
code:8 Value data:"null"
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.ini tiateCallbackStream(CallbackHandler.java:47)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.requestStream(RemoteVMServerThread.java:420)
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:546)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility.introspect(BeanInfoDecoratorUtility.java:220)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:767)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:428)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:415)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1272)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEvents(J avaClassImpl.java:1304)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2311)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1280)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllEvent s(JavaClassImpl.java:1326)
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:66)
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:99)
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:170)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:372)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:463)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.handleParseable(JavaSourceTranslator .java:429)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.run(JavaSourceTranslator.java:502)
org.eclipse.ve.internal.java.codegen.java.SnippetParseJob.do Run(SnippetParseJob.java:92)
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
Re: UI Windows do not show up anymore... [message #132396 is a reply to message #132382] Sat, 21 October 2006 23:20 Go to previous messageGo to next message
Hi again,
I get this kind of exceptions in the log (the warning appears for almost
every constructor call, not only the one shown below):
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-22 05:18:17.343
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:357)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$5. getResource(BeaninfoNature.java:233)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResourceFromHandlers(ProjectResourceSetImpl.java:1 08)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.delegatedGetResource(ProjectResourceSetImpl.java:61)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:372)
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:92)
!ENTRY org.eclipse.ve.java.core 2 0 2006-10-22 02:32:18.078
!MESSAGE
+++ Warning +++: Sun Oct 22 02:32:18 IST 2006 Skipping expression:
txtMaximumIterationsPerClient = new Text(cmpSimulationParameters, SWT.BORDER
| SWT.RIGHT)
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-22 02:32:18.078
!MESSAGE Invalid PropertyDecorator
Re: UI Windows do not show up anymore... [message #132472 is a reply to message #132396] Mon, 23 October 2006 19:09 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Try clearing the cache.
1) Bring up a VE, then close it and all other VE's.
2) Do Project->Clean...->Clean All and wait for build to complete.
3) Now try a VE.
Rich Kulp
Re: UI Windows do not show up anymore... [message #132510 is a reply to message #132472] Thu, 26 October 2006 03:09 Go to previous messageGo to next message
Hi Rich,
i've tried this again but it doesn't work.... I get "this" and "sShell" as
icons only on the visual part of the class.
Thanks a lot
RL
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ehji2e$vr8$2@utils.eclipse.org...
> 3) Now try a VE.
> Rich Kulp
Re: UI Windows do not show up anymore... [message #132521 is a reply to message #132510] Wed, 25 October 2006 16:50 Go to previous messageGo to next message
If it's getting the same errors, then I don't know. Sorry.
Harel Ben Attia wrote:
> Hi Rich,
> Thanks a lot
> RL
>> 3) Now try a VE.
>> Thanks,
>> Rich Kulp
Rich Kulp
Re: UI Windows do not show up anymore... [message #132534 is a reply to message #132521] Thu, 26 October 2006 08:31 Go to previous message
Thanks a lot anyway. I think i'll open a bug for this.
RL
news:ehoimo$thr$3@utils.eclipse.org...
>> Hi Rich,
>> as icons only on the visual part of the class.
>> Thanks a lot
>> RL
>>> 3) Now try a VE.
>>> Thanks,
>>> Rich Kulp
> Rich Kulp
Re: UI Windows do not show up anymore... [message #614723 is a reply to message #132382] Sat, 21 October 2006 23:20 Go to previous message
Hi again,
!STACK 0
!MESSAGE
| SWT.RIGHT)
Re: UI Windows do not show up anymore... [message #614729 is a reply to message #132396] Mon, 23 October 2006 19:09 Go to previous message
3) Now try a VE.
Rich Kulp
Re: UI Windows do not show up anymore... [message #614732 is a reply to message #132472] Thu, 26 October 2006 03:09 Go to previous message
Hi Rich,
Thanks a lot
RL
> 3) Now try a VE.
> Rich Kulp
Re: UI Windows do not show up anymore... [message #614733 is a reply to message #132510] Wed, 25 October 2006 16:50 Go to previous message
> Hi Rich,
> Thanks a lot
> RL
>> 3) Now try a VE.
>> Thanks,
>> Rich Kulp
Rich Kulp
Re: UI Windows do not show up anymore... [message #614734 is a reply to message #132521] Thu, 26 October 2006 08:31 Go to previous message
RL
>> Hi Rich,
>> Thanks a lot
>> RL
>>> 3) Now try a VE.
>>> Thanks,
>>> Rich Kulp
> Rich Kulp
Previous Topic:Cannot view subclassed form
Next Topic:Cannot view subclassed form
Current Time: Sun Sep 07 19:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.05145 seconds
