Home » Newcomers » Newcomers » JRE 5.0
JRE 5.0 [message #132309] Thu, 26 January 2006 21:25 Go to next message
Originally posted by: jtrink.gmail.com
Hello, I just installed Eclipse 3.1 and installed a java platform. Now,
i'm trying to write things using ArrayLists and Scanners. I continually
get the error that the ArrayList in eclipse doesn't have the java platform
updated to 5.0. I know for a fact that i updated to 5.0...does anyone
have any ideas????
Re: JRE 5.0 [message #132322 is a reply to message #132309] Thu, 26 January 2006 22:25 Go to previous messageGo to next message
> platform updated to 5.0. I know for a fact that i updated to 5.0...does
> anyone have any ideas????
You can set the compiler compliance level for all projects under the
java preferences or at the project level.
At the project level:
- select the project
- right click and select properties.
- select java compiler.
- Here you can set compiler compliance level
- set it to 5.0
You should then be ok..
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: JRE 5.0 [message #132360 is a reply to message #132322] Thu, 26 January 2006 23:03 Go to previous messageGo to next message
Well, i installed it and set it to 5.0 and it STILL won't work! i download
the Java SDK 5.0 kit at www.java.com i don't know why this doesn't work.
I'm in deep trouble if i can't get this program coded out by tomorrow...
Re: JRE 5.0 [message #132395 is a reply to message #132360] Fri, 27 January 2006 00:29 Go to previous messageGo to next message
> download the Java SDK 5.0 kit at www.java.com i don't know why this
> doesn't work. I'm in deep trouble if i can't get this program coded out
> by tomorrow...
What is the exact message you are getting?
Re: JRE 5.0 [message #132419 is a reply to message #132395] Fri, 27 January 2006 00:45 Go to previous messageGo to next message
>> out by tomorrow...
After you installed 1.5 did you let Eclipse know where you installed it.
Go to the menu:
- Select Windows -> preferences -> Java -> Installed JRE
If it's not there then
- Select Add
- Add same name to say JRE 1.5.0_6
- Select Browse to the Java JRE home directory (For me it's:
C:\Program Files\Java\jre1.5.0_06 )
- Save and your done.
- You may want to create a new project an work from there. It's the
quickest way to get going.
Re: JRE 5.0 [message #132551 is a reply to message #132419] Fri, 27 January 2006 10:34 Go to previous messageGo to next message
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
> Go to the menu:
> - Select Add
I would highly recommend using a SDK to compile code. Using a JRE, you
might not get deprecation warnings since the JRE is purged from any
deprecated information.
A JRE is fine to execute the code.
Olivier
Re: JRE 5.0 [message #132565 is a reply to message #132551] Fri, 27 January 2006 11:58 Go to previous message
Olivier Thomann wrote:
>> Go to the menu:
>> - Select Add
> Olivier
I use the JRE and I get deprecation warnings where needed. I have not
looked into this because I did not care. Since Eclipse has their own
compiler where does Eclipse compiler end and the class file to JVM for
Sun Start?
Previous Topic:No debug symbols in CDT
Next Topic:Debugging your program
Current Time: Wed Jul 16 05:36:55 EDT 2025
Powered by FUDForum. Page generated in 0.11668 seconds
