the cvs address does not exist! [message #12085] |
Mon, 22 September 2008 07:51  |
hi,i am a new guy,i try to download the source from the cvs ,but there is
a error as following:
could not connect to
pserver:anonymous@dev.eclipse.org:/cvsroot/rt/org.eclipse.riena I/O
exception occurred:Connection refused:cvs [pserver
aborted]:/cvsroot/rt/org.eclipse.riena:no such repository
thanks for your answer!
Re: the cvs address does not exist! [message #12098 is a reply to message #12085] |
Tue, 23 September 2008 05:07  |
> is a error as following:
The address is actually host:dev.eclipse.org repository:/cvsroot/rt and then
the base tree for riena projects is org.eclipse.riena. When you specify the
CVS repository in eclipse you only specify pserver:anonymous@dev.eclipse.org/cvsroot/rt
hope that helps
christian campo
Re: the cvs address does not exist! [message #575173 is a reply to message #12085] |
hope that helps
christian campo
FUDForum. Page generated in 0.03311 seconds
