Home » Eclipse Projects » GEF » problem with undo command
problem with undo command [message #132205] Fri, 14 May 2004 11:42 Go to next message
Originally posted by: paolino125.hotmail.com
Hi, I'm building a graphical editor with gef. Look at flow example I've
implemented a deleteCommand; when i delete a figure all works, but when I
try to undo the command I get:
org.eclipse.gef.editparts.AbstractEditPart.getRoot(AbstractE ditPart.java:580
org.eclipse.gef.editparts.AbstractEditPart.getViewer(Abstrac tEditPart.java:6
30)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.createOr FindConnection(A
bstractGraphicalEditPart.java:285)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshT argetConnections
(AbstractGraphicalEditPart.java:640)
org.eclipse.dylog.editors.graphical.part.ActivityPart.proper tyChange(Activit
yPart.java:107)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at org.eclipse.dylog.model.Activity.firePropertyChange(Activity .java:81)
at org.eclipse.dylog.model.Activity.addTargetConnection(Activit y.java:99)
org.eclipse.dylog.model.command.DeleteCommand.restoreConnect ions(DeleteComma
nd.java:88)
org.eclipse.dylog.model.command.DeleteCommand.undo(DeleteCom mand.java:115)
at org.eclipse.gef.commands.CompoundCommand.undo(CompoundComman d.java:169)
at org.eclipse.gef.commands.CommandStack.undo(CommandStack.java :229)
It seems that the editPart I've added dosn't have a parent!Idon't understand
how it's possible!
Please help me. Thanks
Re: problem with undo command [message #132350 is a reply to message #132205] Mon, 17 May 2004 09:34 Go to previous messageGo to next message
It sounds like you have a dangling EditPart which is still listening to the
model. Make sure you unhook and model listeners in deactivate(), and allow
the editparts to get GCed.
"funky79" <paolino125@hotmail.com> wrote in message
news:c82ovk$26b$1@eclipse.org...
> java.lang.NullPointerException
> at
> at
> 30)
> at
> at
> at
> yPart.java:107)
> at
> nd.java:88)
> at
understand
> how it's possible!
Re: problem with undo command [message #132387 is a reply to message #132350] Mon, 17 May 2004 09:41 Go to previous message
Yes, it's right!
Thanks!
"Randy Hudson" <none@us.ibm.com> ha scritto nel messaggio
news:c8aejs$37q$1@eclipse.org...
the
allow
I
> > at
> > at
> > 30)
> > at
> > at
> > at
> > yPart.java:107)
> > at
> > at
> > nd.java:88)
> > at
> > at
> understand
> > how it's possible!
Previous Topic:Using tool tip for target feedback
Next Topic:GEF with eclipse 3.0 M08
Current Time: Sun Jul 27 12:38:31 EDT 2025
Powered by FUDForum. Page generated in 0.03110 seconds
