The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132185] |
Fri, 17 February 2006 09:26  |
Originally posted by: harikrishnan_j2003.rediffmail.com
Sir,
When i run the sample code given in RunTimeEngine API which will
convert the .rptdesign file into HTML file,i am getting the error
not found. Error code:EXTENSION_POINT_NOT_FOUND
I am using birt-runtime2_0_0
Eclipse3.1.1
JDK1.5.0
EMF2.1.1
GEF3.1.1
how to resolve this.
Thankyou
Harikrishnan J.
Re: The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132517 is a reply to message #132495] |
Sat, 18 February 2006 09:19  |
Sir,
I Apologize for the reply i have sent in response to your
answer,Although it throws that error ,it didn,t place any Hurdle in
Executing the code successfully and i got output in HTML & PDF Format,
which i didn't seen ,when i sent the first reply to your answer.Ignore the
Reply i have sent to you
asking how to Execute that code successfully.
I once again Thankyou for guiding me.
Thankyou
Harikrishnan J.
FUDForum. Page generated in 0.04226 seconds
