Kertasarie VM [message #12066] |
Fri, 04 May 2007 09:35  |
Originally posted by: Slawi.gmx.de
Hello together,
i'm doing currently my first steps in developing SW for embedded devices.
The current target device is a compaq with a WM 2002,
my aim is to evauluate an application with sockets and JNI. I wrote
already the java code for the usuall Java VM.
So - i read some paper and detected the Kertasarie VM.
I'm used to developing with eclipse but the Kertasarie doesn't offer any
libraries or similar stuff which i could use. Has someone experience with
this stuff?
Is there an API i could import into eclipse? Maybe even the text file API
which is availbe in the Kertasarie package, part of the avaiable text file:
de.uniro.ui.Bitmap
public class Bitmap extends Control{}
de.uniro.ui.Button
public class Button extends Control{}
public Button(String label, int x, int y, int width, int height){}
Maybe you can propose an other JVM (J2ME) for this scenario?
FUDForum. Page generated in 0.30972 seconds
