Home » Eclipse Projects » Remote Application Platform (RAP) » Order of resources / external JS libraries
Order of resources / external JS libraries [message #131945] Thu, 07 May 2009 20:47 Go to next message
Originally posted by: AM-81.web.de
I need to load some external JS libraries in a special order in my RAP
application, because there are some dependencies between them.
Is der a possibility to do this? In an HTML file I declare them
at the head and it works fine all the time.
Now I try to do the same with resources in the
org.eclipse.rap.ui.resources extension, but it doesn't work.
Without any changes it sometimes works and sometimes I get some JS
errors, that a class is not defined or unknown.
Is there a reason why the resources are not always called in the same order?
Thanks for hints
André
Re: Order of resources / external JS libraries [message #132027 is a reply to message #131945] Fri, 08 May 2009 12:08 Go to previous messageGo to next message
Andre,
the internal storage of the extension registry seems not to care
about the order in which extensions were declared.
However I think this should be solved within RAP. An attribute to
specify the order or something like a composite resource extension
in which the application developer can return th resources in a
specific order is needed. Feel free to file an enhancement request.
In the meanwhile you could circumvent the issue if concatenate the
JS files in the right oder and register them as one resource.
HTH
Rüdiger
André Müller wrote:
> order?
> Thanks for hints
> André
Re: Order of resources / external JS libraries [message #132657 is a reply to message #132027] Wed, 13 May 2009 07:57 Go to previous messageGo to next message
Hi Rüdiger,
I do what you said. I register now only one resource and dynamically
register my libraries with js in the head.
Thanks for your help. :)
Maybe someone has the same problem, here is my code in the registered
js-file:
var scriptElement1 = document.createElement('script');
scriptElement1.type = 'text/javascript';
scriptElement1.src = '<jsLibrary1>.js';
var scriptElement2 = document.createElement('script');
scriptElement2.type = 'text/javascript';
scriptElement2.src = '<jsLibrary2>.js';
var head = document.getElementsByTagName('head')[0];
if( head ){
head.appendChild( scriptElement1 );
head.appendChild( scriptElement2 );
alert('short break');
the only not so nice thing is, the alert at the end. but it is needed,
otherway it could be that the tags would not correctly registered.
Rüdiger Herrmann schrieb:
> Andre,
> the internal storage of the extension registry seems not to care about
> specify the order or something like a composite resource extension in
> which the application developer can return th resources in a specific
> In the meanwhile you could circumvent the issue if concatenate the JS
> HTH
> Rüdiger
> André Müller wrote:
>> order?
>> Thanks for hints
>> André
Re: Order of resources / external JS libraries [message #132696 is a reply to message #132657] Wed, 13 May 2009 08:51 Go to previous message
André,
just for the record, my suggestion was to *concatenate* the files.
I.e. copy the contents of fileA and fileB into a fileAB and register
this file instead.
That would save you the alter for the price of having a lengthy,
maybe harder to edit file.
Rüdiger
André Müller wrote:
> Hi Rüdiger,
> js-file:
> if( head ){
>> Andre,
>> HTH
>> Rüdiger
>> André Müller wrote:
>>> Hi,
>>> RAP application, because there are some dependencies between them.
>>> order?
>>> Thanks for hints
>>> André
Previous Topic:setTextLimit for Text Doesn't Work?
Next Topic:Strange behavior of FilteredTree
Current Time: Tue Jul 08 17:17:36 EDT 2025
Powered by FUDForum. Page generated in 0.04056 seconds
