Home » Archived » Test and Performance Tools Platform (TPTP) » IWAT4022E An error occurred during report generation.
IWAT4022E An error occurred during report generation. [message #131890] Mon, 30 June 2008 19:53 Go to next message
Originally posted by: theodore.larsonfreeman.boeing.com
I am profiling a JBOSS application in standalone mode using TPTP 4.5.0 and
analyzing the trace files in Eclipse 3.4.0. (The problem described below
also occurs when using TPTP 4.4.1 and Eclipse 3.3.2.)
I can create trace files in either XML or binary format, and analyze them
in Eclipse. But in either case when I attempt to create a report from the
New Report dialog, I get an error. If I try to create a CSV or HTML trace
report, I get an error such as this:
Error: For input string "3,275.290732"
When I try to create an XML trace statistics report from the same trace
file, I get this error:
Error: java.lang.NullPointerException
The trace files are typically tens of MB in size. I will look for a
smaller file that causes the error if that will help.
Is this a bug? Thanks for any thoughts on how to fix the issue.
Ted Larson Freeman
Re: IWAT4022E An error occurred during report generation. [message #131978 is a reply to message #131890] Wed, 02 July 2008 07:18 Go to previous messageGo to next message
Hi Ted,
The BIRT Reports (test, log, trace, and statistical BIRT report
generators) were moved from a General Availability (GA) component to an
As-Is component in TPTP 4.5. As-Is components are primarily provided for
prior users but imply no support (for example, defects, news group, and
mailing lists) or commitment to triage or resolve opened defects. Although
this symptom appears to be a defect, for it to be considered, please open
with an attached patch including code to resolve the symptom and test cases
to test the fix.
Paul
"Ted Larson Freeman" <theodore.larsonfreeman@boeing.com> wrote in message
news:50d1ede4e5e0db8b32c63763e2993765$1@www.eclipse.org...
> Ted Larson Freeman
Re: IWAT4022E An error occurred during report generation. [message #132164 is a reply to message #131978] Mon, 07 July 2008 12:50 Go to previous messageGo to next message
Paul Slauenwhite wrote:
> Hi Ted,
> to test the fix.
> Paul
>> Ted Larson Freeman
Thanks, Paul.
I'd like to know more about this change in priority. Has the status of
support for BIRT report generation been changed because there is a better
way to generate reports? If so, I'll switch. Otherwise I may look into
fixing the issue myself, as you suggest.
Ted
Re: IWAT4022E An error occurred during report generation. [message #132190 is a reply to message #132164] Tue, 08 July 2008 06:53 Go to previous message
Hi Ted,
The support for generating BIRT reports in TPTP has not changed, but
rather the actual report generators/templates (test, log, trace, and
statistical BIRT). Users can either use the existing report
generators/templates 'as-is' or created their own using the TPTP extension
points. The decision to move the report generators/templates to an as-is
component was based on a decrease in staffing on the project and not for
technical reasons.
Paul
news:6c674059a3c94ace72049c1afd6f1c7f$1@www.eclipse.org...
>> Hi Ted,
>> Although this symptom appears to be a defect, for it to be considered,
>> please open with an attached patch including code to resolve the symptom
>> and test cases to test the fix.
>> Paul
>>>and analyzing the trace files in Eclipse 3.4.0. (The problem described
>>>below also occurs when using TPTP 4.4.1 and Eclipse 3.3.2.)
>>> them in Eclipse. But in either case when I attempt to create a report
>>> from the New Report dialog, I get an error. If I try to create a CSV or
>>> HTML trace report, I get an error such as this:
>>> Ted Larson Freeman
> Thanks, Paul.
> Ted
Previous Topic:Autonomic Computing | Help Required
Next Topic:Coverage Statistics in TPTP 4.5.0
Current Time: Sat Jul 26 08:26:41 EDT 2025
Powered by FUDForum. Page generated in 0.03812 seconds
