Home » Newcomers » Newcomers » Configuring Eclipse 3.1 with Ext plugins
Configuring Eclipse 3.1 with Ext plugins [message #131655] Tue, 24 January 2006 12:42 Go to next message
Originally posted by: james.s.globe.L-3com.com
I just downloaded the latest version of eclipse SDK, v3.1.1 and I tried
installing the eclipse RCP-3.1.1 binaries and source. I get the following
error in the log file.....(I can't cut-n-paste the contents b/c the dev
machine is classified).
!Entry org.eclipse.osgi 2006-01-24
!Message Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service
org.eclipse.core.runtime.adaptor.Eclipsestarter.run(Eclipses tarter.java:367)
org.eclipse.core.runtime.adaptor.Eclipsestarter.run(Eclipses tarter.java:163)
and more lines of the same stack trace dump....until you get to main
method.
at org.eclipse.launcher.Main.main(Main.java:948)
Bascially what I did was install eclipse on XP platform via unzip and
install the "eclipse-RCP-SDK-3.1.1-win32.zip" via unzip into eclipse
installation directory.
Any help is appreciated.
Re: Configuring Eclipse 3.1 with Ext plugins [message #131856 is a reply to message #131655] Wed, 25 January 2006 04:55 Go to previous message
Originally posted by: daniel.megert.eclipse.org
> tried installing the eclipse RCP-3.1.1 binaries and source. I get the
> following error in the log file.....(I can't cut-n-paste the contents
> b/c the dev machine is classified).
> !STACK 1
> at
> at
> method.
Don't install both. Either install RCP or the Eclipse SDK and make sure
unzip preserves the directory structure from the zip.
Dani
Previous Topic:Mandar mail desde vb6.0
Next Topic:Installation on MacOSX 10.4.4
Current Time: Fri Jul 18 02:10:51 EDT 2025
Powered by FUDForum. Page generated in 0.21311 seconds
