| Marker problem [message #131523] |
Thu, 18 September 2003 05:07  |
Originally posted by: parag.sawant.patni.com
I have been facing a problem. Was wondering how to resolve the same.
I have created a plug-in to open a file in a file editor.
The contents are editable and need to be validated before saving the file.
Now when I open two files say File1 and File2 with the plugin,
and work on the first one.
I get a validation error Error 1 since I enter an invalid property. A
marker is created to display that to the user in the Task list.
Now I shift to File 2 and enter a valid change in the file and save. Since
there was no error, there is no marker for the same. However even the
earlier marker gets deleted in the process.
I am following the following sequence:
1. Open file
2. (user makes some changes)
3. validation
4. success ---> No marker is created
5. failure ---> Earlier markers deleted (since if there was an earlier
error,
it has to be removed)
New marker is created with the Error message.
Please tell me if I am doing anything wrong.
How do I create a separate marker for every file that I open so that I can
delete markers specific to only that file?
| Re: Marker problem [message #131604 is a reply to message #131591] |
Thu, 18 September 2003 06:09  |
Originally posted by: daniel.megert.gmx.net
Parag Sawant wrote:
>Hi Dani,
>How do I associate a marker to each of the file (resource) I open?
see IResourcle.createMarker, IResource.deleteMarkers
>If I can get this right, I can also attach and remove the same from the
>respective resource.
>Do I have to specify it as persistent using the extension point of the
>problemmarker??
No.
>regards,
>Parag
>Daniel Megert wrote:
>>Do you attach/remove the marker to/from the right resource i.e. file1
>>and file2?
>>Dani
>>PCS wrote:
>>>Hi,
>>>1. Open file
>>>3. validation
>>>error,
FUDForum. Page generated in 0.03417 seconds
