Home » Eclipse Projects » Remote Application Platform (RAP) » ArrayIndexOutOfBoundsException in ConcurrentTableUpdator
ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #131401] Tue, 05 May 2009 07:54 Go to next message
I am using a virtual table with a deffered content provider, a sorter and a
filter. Now, sometimes I get an endless loop because of an
ArrayIndexOutOfBoundsException (for index 64).
The bad thing is that it does not occur always. The good thing is, that I
might know what causes the problem.
In ConcurrentTableUpdater there is a method pushClear(int toClear). There is
a variable "lastClear" which is somtimes ">=" the length of the array
"pendingClear" (I don't know why though). Looking deeper at the method I
noticed, that there is already a condition that checks it and the the code
"seems" to extend the array to twice the length of "lastClear".
I wrote "seems" in quotation mark because it actually does not extend the
array!
The initial capacity of the array "pendingClear" is MIN_FLUSHLENGTH (64).
Now, within the condition the new capacity is calculated using
Math.min(MIN_FLUSHLENGTH, lastClear * 2). So if "lastClear" is bigger than
or equal to the length of the array "pendingClear" it will not extend it,
since AGAIN the capacity is set to MIN_FLUSHLENGTH since Math.min() is used!
That does not make sense in my eyes. I would expect, that the size of the
array is extended in this condition, because other wise the line
pendingClears[lastClear++] = toClear will throw an
ArrayIndexOutOfBoundsException.
Using Math.max() solves the problem and no ArrayIndexOutOfBoundsException
will occur anymore.
I don't know why this condition is made if actually the array will never be
extended.
I check with RCP jface code which is equal to RAP code, but again, the array
will never be extended. Maybe this is a bug in RCP, too.
Markus
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #131425 is a reply to message #131401] Tue, 05 May 2009 09:31 Go to previous messageGo to next message
One addition:
actually you don't even need using Math.max(). Since the condition defines,
that (lastClear >= the length of the array "pendingClear") than you can
always use:
int new Capacity = lastClear * 2;
"Markus Kr
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #131558 is a reply to message #131401] Wed, 06 May 2009 06:14 Go to previous messageGo to next message
Markus,
it looks like a bug. If you want to file a bugzilla, please check
whether this is an issue in RCP or RAP and choose the component
accordingly.
Rüdiger
Markus Krüger wrote:
> Hello,
> array!
> will occur anymore.
> extended.
> Markus
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #131633 is a reply to message #131558] Wed, 06 May 2009 13:30 Go to previous messageGo to next message
I have never reported anything for RCP but as RAP apots its code from RCP I
assume it is an RCP bug.
Anyway would you ever fix this before it would eb fixed in RCP, or do you
have to wait for them to change?
Since it is an easy bug, and just one line of code to change, isn't there a
short way you can go to have this fixed in RCP and RAP very soon?
Markus
"R
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #131643 is a reply to message #131633] Wed, 06 May 2009 16:03 Go to previous messageGo to next message
Unlikely, but it might be that this is already fixed in RCP, that's
why I asked you to check with RCP.
We would prefer to have it first fixed in RCP because they know best
their code, have all the test suites. We just adopt it and make it
multi-user.
We would need a bug plus a patch in any case. I would suggest to
open the bug against RCP. If you report the bug id here, we will
monitor it and adopt the changes for RAP when they are blessed by
the RCP guys.
> Markus
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
> news:gtrnua$2v8$1@build.eclipse.org...
>> Markus,
>> it looks like a bug. If you want to file a bugzilla, please check whether
>> this is an issue in RCP or RAP and choose the component accordingly.
>> Cheers,
>> Rüdiger
>>> Hello,
>>> a filter. Now, sometimes I get an endless loop because of an
>>> is a variable "lastClear" which is somtimes ">=" the length of the array
>>> code "seems" to extend the array to twice the length of "lastClear".
>>> array!
>>> than or equal to the length of the array "pendingClear" it will not
>>> extend it, since AGAIN the capacity is set to MIN_FLUSHLENGTH since
>>> Math.min() is used! That does not make sense in my eyes. I would expect,
>>> that the size of the array is extended in this condition, because other
>>> wise the line pendingClears[lastClear++] = toClear will throw an
>>> will occur anymore.
>>> be extended.
>>> array will never be extended. Maybe this is a bug in RCP, too.
>>> Regards,
>>> Markus
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #132346 is a reply to message #131633] Tue, 12 May 2009 07:51 Go to previous messageGo to next message
Markus,
please verify that your case is the same like in this bug:
[Viewers] ArrayIndexOutOfBoundsException exception in
ConcurrentTableUpdator (used in DeferredContentProvider)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=165637
Best,
Ivan
"Markus Kr�������������������
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #132631 is a reply to message #132346] Wed, 13 May 2009 07:28 Go to previous messageGo to next message
Hi Ivan
yes, it is exactly the same issue!
Markus
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:gubnrr$jrk$1@build.eclipse.org...
> Markus,
> Best,
> Ivan
>> I assume it is an RCP bug.
>> a short way you can go to have this fixed in RCP and RAP very soon?
>> Regards,
>> Markus
>> "R?diger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
>>> Markus,
>>> accordingly.
>>> Cheers,
>>> R?diger
>>> Markus Kr?ger wrote:
>>>> Hello,
>>>> and a filter. Now, sometimes I get an endless loop because of an
>>>> I might know what causes the problem.
>>>> There is a variable "lastClear" which is somtimes ">=" the length of
>>>> the array "pendingClear" (I don't know why though). Looking deeper at
>>>> the method I noticed, that there is already a condition that checks it
>>>> and the the code "seems" to extend the array to twice the length of
>>>> "lastClear".
>>>> the array!
>>>> (64). Now, within the condition the new capacity is calculated using
>>>> expect, that the size of the array is extended in this condition,
>>>> because other wise the line pendingClears[lastClear++] = toClear will
>>>> throw an ArrayIndexOutOfBoundsException.
>>>> ArrayIndexOutOfBoundsException will occur anymore.
>>>> never be extended.
>>>> Regards,
>>>> Markus
Re: ArrayIndexOutOfBoundsException in ConcurrentTableUpdator [message #132670 is a reply to message #132631] Wed, 13 May 2009 08:05 Go to previous message
Markus,
this bug is almost 3 years old and it is still not fixed. Maybe if you
provide a RCP snippet to reproduced it, this will speedup the process.
Best,
Ivan
Previous Topic:Minor renamings in theming
Next Topic:Marking in the process image
Current Time: Thu Jul 17 19:12:14 EDT 2025
Powered by FUDForum. Page generated in 0.07015 seconds
