Home » Eclipse Projects » Remote Application Platform (RAP) » Undeploying RAP Application on Tomcat
Undeploying RAP Application on Tomcat [message #131304] Tue, 05 May 2009 03:48 Go to next message
Hi all,
How do you guys stop RAP application on Tomcat ?
If I try the normal way through Tomcat manager, it always hangs as if it
waited for something with message 'INFO: Waiting for 1 instance(s) to be
deallocated' on the console. I've tried to deploy without -console
parameter but the problem persists. Eventually I have to shut it down
(Ctrl+C) each time I need to redeploy RAP application.
Setya
Re: Undeploying RAP Application on Tomcat [message #131350 is a reply to message #131304] Tue, 05 May 2009 04:09 Go to previous messageGo to next message
Hi!
In most cases I stops like you but - "killall -9 jsvc". :-)
Probably some thread in the RAP is can`t stop.
Re: Undeploying RAP Application on Tomcat [message #131463 is a reply to message #131304] Tue, 05 May 2009 13:28 Go to previous messageGo to next message
Yetya,
your problem may be related to this bug:
214464: [UICallback] Unable to close equinox if activated
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214464
Rüdiger
Setya wrote:
> Hi all,
> Setya
Re: Undeploying RAP Application on Tomcat [message #131501 is a reply to message #131463] Tue, 05 May 2009 22:56 Go to previous messageGo to next message
Rudiger,
Thanks for your pointer. But the bug is more than 1 year old and there
is not much activity there.
Setya
Re: Undeploying RAP Application on Tomcat [message #131533 is a reply to message #131304] Wed, 06 May 2009 04:40 Go to previous messageGo to next message
Hi Setya,
if you clean all sessions before, undeploying usually works fine for us.
Stefan.
Setya schrieb:
> Hi all,
> Setya
Re: Undeploying RAP Application on Tomcat [message #131546 is a reply to message #131533] Wed, 06 May 2009 05:30 Go to previous messageGo to next message
Stefan,
Thanks for your advice.
I also experience the same. If after deploying no session was yet
created I can undeploy just fine. But what do you mean by clean all
sessions ?
Setya
Re: Undeploying RAP Application on Tomcat [message #131569 is a reply to message #131546] Wed, 06 May 2009 06:52 Go to previous messageGo to next message
> sessions ?
In TomcatManager you can invalidate all open sessions. Click on the
number of sessions, select them all, and click on the button "Invalidate
selected Sessions".
Stefan.
Re: Undeploying RAP Application on Tomcat [message #131583 is a reply to message #131569] Wed, 06 May 2009 07:15 Go to previous message
> selected Sessions".
It works. Thanks a lot.
Setya
Previous Topic:Synchronize widget
Next Topic:URL encoding not properly handled in RWT.getRequest.getParameter()?
Current Time: Tue Jul 08 09:19:06 EDT 2025
Powered by FUDForum. Page generated in 1.10670 seconds
