Synchronize widget [message #131280] |
Mon, 04 May 2009 15:42  |
I have an embded flash inside RAP widget, and I want synchronize
different flash compenents using XML file(to have same thing in all users
flash) without using thread.
thx
Re: Synchronize widget [message #131994 is a reply to message #131704] |
Fri, 08 May 2009 11:23  |
Hi Ralf,
I used a flash widget inside RAP, the idea is that if one user make
change all users must see what he is drawing, the simple way, is to put a
thread inside the widget, and this thread make the update, but it's not a
good solution, I make a search and the best way is to go through OSGI
EventAdmin, now my problem I dont know how to bind the EventAdmin to the
Event Publisher !!! I found an example but they give an jar file (witch
used us an dependency) and when I want to deployed it it give me an class
not found error because OSGI container need source I think!!!
so if you know how to make an eventadmin listener it w'll be helpful
thank you
FUDForum. Page generated in 0.03622 seconds
