Home » Eclipse Projects » Remote Application Platform (RAP) » Synchronize widget
Synchronize widget [message #131280] Mon, 04 May 2009 15:42 Go to next message
I have an embded flash inside RAP widget, and I want synchronize
different flash compenents using XML file(to have same thing in all users
flash) without using thread.
thx
Re: Synchronize widget [message #131704 is a reply to message #131280] Thu, 07 May 2009 05:46 Go to previous messageGo to next message
Hi Andre,
I didn't quite understand what you are trying to achieve, could you
describe your case in some more detail? Do you use custom widget? What
is the idea about this XML file?
Ralf
> users flash) without using thread.
> thx
Re: Synchronize widget [message #131994 is a reply to message #131704] Fri, 08 May 2009 11:23 Go to previous message
Hi Ralf,
I used a flash widget inside RAP, the idea is that if one user make
change all users must see what he is drawing, the simple way, is to put a
thread inside the widget, and this thread make the update, but it's not a
good solution, I make a search and the best way is to go through OSGI
EventAdmin, now my problem I dont know how to bind the EventAdmin to the
Event Publisher !!! I found an example but they give an jar file (witch
used us an dependency) and when I want to deployed it it give me an class
not found error because OSGI container need source I think!!!
so if you know how to make an eventadmin listener it w'll be helpful
thank you
Previous Topic:Issues with Upload Widget
Next Topic:Undeploying RAP Application on Tomcat
Current Time: Fri Jul 18 20:52:41 EDT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
