Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Custom import from java annotations
| Custom import from java annotations [message #131138] |
Wed, 03 December 2008 14:58  |
I'd like to be able to import all classes and attributes from a specific
package and I'd like to avoid having to add manually @model to each element.
Is there an easy way to do that?
| Re: Custom import from java annotations [message #131308 is a reply to message #131214] |
Thu, 04 December 2008 12:52   |
Ed Merks wrote:
> Erik,
> No, we don't have a way to do that. It would for sure be very useful to
> have something like this. I.e., some type of wizard that would gather
> up all the potential model information and then let you edit it. It
> would kind of need to be smart though, because if you put @model on a
> setX method, it will become an operation when likely, if there is a getX
> method, you'd not even want the @model on the setX because it's just the
> set accessor for the "X" feature. It's not likely this will ever exist
> unless someone contributes it...
To start, do you know where the "import from annotation" is implemented?
I don't think the set/get should be too difficult to handle, also there
is more custom stuff I'd like to import in the model such as java 5
annotation...
Erik.
| Re: Custom import from java annotations [message #131321 is a reply to message #131308] |
Thu, 04 December 2008 12:59  |
Erik,
All the magic happens in
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder. A brute force
approach might be to make it behave as if everything had @model on it
and then filter down the result...
Erik Putrycz wrote:
> Ed Merks wrote:
>> Erik,
>> to have something like this. I.e., some type of wizard that would
>> gather up all the potential model information and then let you edit
>> it. It would kind of need to be smart though, because if you put
>> @model on a setX method, it will become an operation when likely, if
>> there is a getX method, you'd not even want the @model on the setX
>> because it's just the set accessor for the "X" feature. It's not
>> likely this will ever exist unless someone contributes it...
> there is more custom stuff I'd like to import in the model such as
> java 5 annotation...
> Erik.
| Re: Custom import from java annotations [message #620423 is a reply to message #131138] |
Thu, 04 December 2008 08:10  |
Erik,
> specific package and I'd like to avoid having to add manually @model
> to each element.
| Re: Custom import from java annotations [message #620510 is a reply to message #131214] |
Ed Merks wrote:
> Erik,
annotation...
Erik.
| Re: Custom import from java annotations [message #620511 is a reply to message #131308] |
Erik,
Erik Putrycz wrote:
> Ed Merks wrote:
>> Erik,
> Erik.
Current Time: Mon Nov 03 04:38:59 EST 2025
Powered by FUDForum. Page generated in 0.28446 seconds
