Home » Archived » M2M (model-to-model transformation) » Problem with clause "using" in called rule
Problem with clause "using" in called rule [message #11967] Mon, 22 January 2007 06:58 Go to next message
Originally posted by: jairson.gmail.com
Hello All,
I´ve read in the manual that called rules allow us to use the clause
"using" to declare local variables. But I am having an error message
"unexpected token: using" with the excerpt below:
rule simpagation2simpagation (r : CHR!Simpagation,v :
Sequence(CHR!VariableSymbol))
using {
co : Sequence(CHR!ConstantSymbol) =
thisModule.allConstantSymbols(r.keep->union(r.remove));
to
ro : CHR!Simpagation (
Can anyone help?
regards,
Jairson Vitorino
Re: Problem with clause "using" in called rule [message #11981 is a reply to message #11967] Mon, 22 January 2007 08:57 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Jairson,
Which ATL compiler version do you have ? ATL 2006 or ATL 2004 ? If it's
2006, try it with 2004 and report us if it is working. This would mean
that ATL 2006 doesn't support "using" in called rules.
Mikael
Jairson a écrit :
> Hello All,
> using {
> to
> Can anyone help?
> regards,
> Jairson Vitorino
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: Problem with clause "using" in called rule [message #11993 is a reply to message #11981] Mon, 22 January 2007 10:14 Go to previous messageGo to next message
Mikaël
Thanks for the answer. I am using ATL 2004! That´s what I found it strange.
here is the whole rule:
using {
to
name <- r.name,
keep <- r.keep,
remove <- r.remove,
guard <- r.guard->union(co->iterate(c; acc : CHR!Bic = Sequence{} |
acc->including(thisModule.newBic(c,thisModule.newVariables- >at(co->indexOf(c)))))),
disjunctiveBody <- r.disjunctiveBody
I still have the same error.
Jairson
Mikaël Barbero wrote:
> Hi Jairson,
> Mikael
> Jairson a écrit :
>> Hello All,
>> using {
>> to
>> Can anyone help?
>> regards,
>> Jairson Vitorino
Re: Problem with clause "using" in called rule [message #12019 is a reply to message #11993] Mon, 22 January 2007 10:13 Go to previous messageGo to next message
Your rule parses ok with the latest version of ATL.
Can you please try to update?
The problem may also be a syntax error earlier in the file. If there is
one, the parser may not have succeeded in resynchronizing. Correcting
any previous error should then make this one disappear.
Frédéric Jouault
Jairson wrote:
> Mikaël
> using {
> to
> name <- r.name,
> keep <- r.keep,
> remove <- r.remove,
> = Sequence{} |
> Jairson
>> Hi Jairson,
>> it's 2006, try it with 2004 and report us if it is working. This would
>> mean that ATL 2006 doesn't support "using" in called rules.
>> Regards,
>> Mikael
>> Jairson a écrit :
>>> Hello All,
>>> using {
>>> to
>>> Can anyone help?
>>> regards,
>>> Jairson Vitorino
Re: Problem with clause "using" in called rule [message #12032 is a reply to message #12019] Mon, 22 January 2007 13:16 Go to previous message
Thanks. I´ll update then.
Frédéric Jouault wrote:
> Hello,
> Frédéric Jouault
> Jairson wrote:
>> Mikaël
>> strange.
>> using {
>> to
>> name <- r.name,
>> keep <- r.keep,
>> remove <- r.remove,
>> Jairson
>>> Hi Jairson,
>>> would mean that ATL 2006 doesn't support "using" in called rules.
>>> Regards,
>>> Mikael
>>> Jairson a écrit :
>>>> Hello All,
>>>> using {
>>>> to
>>>> Can anyone help?
>>>> regards,
>>>> Jairson Vitorino
Previous Topic:Problem with UML profiles and ATL 2006 - Message #2052 @yahoo list
Next Topic:[ATL] transform model to model
Current Time: Sat Jun 07 08:29:38 EDT 2025
Powered by FUDForum. Page generated in 0.03933 seconds
