BIRT Source Reorganization [message #11966] |
Mon, 28 February 2005 14:31 |
The BIRT project source code in Eclipse CVS has been reorganized. You will
now find all source code in a single module "source" under the BIRT CVS
home (/home/birt).
This change affects how you download BIRT source code. You should use CVS
client to check out all directories under /home/birt/source (Note: Do NOT
check out the /home/birt/source directory itself).
If you had previously downloaded BIRT source code, you will need to re-map
your local source folders to the correct CVS folders in their new
locations in order to be able to receive future CVS updates. In many
cases, it may be easier to simply delete your local source and check out
the CVS projects again.
Please note that there is presently an obsolete module
org.eclipse.birt.converters left in the BIRT CVS root. Do not download or
use this module. This correct path of this project is
/home/birt/source/org.eclipse.birt.converters. The obsolete module will be
removed in the coming days.
regards,
Gary Xue
Actuate Corp.
FUDForum. Page generated in 0.04792 seconds
